MAF Issues... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2007, 10:04 AM   #1 (permalink)
View flyinby's Photo Gallery
MAF Issues...
Quick question guys, i have a 91 celica w/ a 3sgte swap and when the gas is put to the floor the maf seems to be throwing a code causing the engine to run in limp. I know its the maf cuz i get out and unplug it... plug it back in and the engine runs fine until i attempt to give it some gas again, is there any way i can test this before i go replacing the thing?
flyinby is offline   Reply With Quote
Old 03-21-2007, 11:29 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
How are you unplugging the MAF?
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 03-21-2007, 12:03 PM   #3 (permalink)
The setup I have has the harness plugging in right on top... very accessable...
Old 03-21-2007, 12:07 PM   #4 (permalink)
I love Cin
I meant my question quite literally ... how are you physically unplugging it?
Are you unscrewing it and popping it off or are you undoing the thin C-clip and popping it off?
If you used the screws, you have damaged the unit.
Old 03-21-2007, 12:31 PM   #5 (permalink)
i am unplugging it where the harness connects, no screws, no c-clips, the unit is a custom setup...air filter, maf, 8" tube, turbo, i am physically unplugging the harness which just clips in...
Old 03-21-2007, 12:38 PM   #6 (permalink)
I love Cin
If it is the stock unit, like the one one the MR2, there should be a thin C-clip that holds the plug in place. If you do not have that clip, maybe your plug is wiggling loose?
What code are you getting?
Old 03-21-2007, 12:58 PM   #7 (permalink)
i am unsure what the code is i have never diagnosed this problem, my c-clip may be missing but i know for a fact that the harness does not disconnect/ come loose, the problem is reacuring at the same point everytime, leading me to believe that the maf has a problem...
Group Buy for PSC1 (15 more HP) Pb 2nd Generation (2005+) 82 12-24-2008 10:33 PM
URD Maf calibrator installed. tacogrande 2nd Generation (2005+) 122 11-21-2007 03:23 PM
Cleaned MAF sensor, Check engine light on cheesycoolguy 1st Generation (1995.5–2004) 13 02-26-2007 04:16 PM
Thing wired to the MAF sensor ticking ... kinda loud??? BLUEMEANIE Hardcore Tech and Competition 5 02-01-2007 10:03 PM
AFM OR MAF how to swap? canadianae92 Archived Corolla threads 7 11-11-2005 01:26 AM
