they aren't the same...... on the 4age the alternator is on the intake side, the 4afe it's on the intake side
however, you can make it fit.... you need to get a piece of metal that's about 1/2" square by 3" long or so.... drill & tap one end (for the slider) and drill a hole at the other..... the top bolt of the 4afe alternator is about 1/2" towards the middle of the case compared to the 4age...
i had a 4afe alternator running on my smallport 4age for about 2 years before it died....
however, being that you have a 97 you might need to rewire the main plug to match what's on your alternator (mid 90's toyota changed the style of the plug from round to oval)
