High Flow Cat Opinions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2007, 02:31 AM   #1 (permalink)
View sw20drift's Photo Gallery
2nd Generation High Flow Cat Opinions
Hey guys, I've got a 91 MR2T and I'm gonna be trying to go through the annual hope I'll pass emissions inspection again. I know I need to get a cat on my car to pass "legally". Right now the car has a Berk Tech DP and HKS Hi power exhaust. I've been looking at the Random Tech 7000 series high flow cats. I've heard good things about the company through Evo owners. Now I believe the HKS exhaust is 2.5" , now would it make more sense to get a converter with the 2.5" in and out pipe, or a 3" in and out? I just basically want to keep the flow as smooth as possible. I should also mention, I'm probably gonna remove the muffler from the HKS exhaust and have the cat mounted in place. The exhaust is too quiet imo, but then again it may get too loud, guess I'll find out. So just wondering what everyones opinion would be going for this setup. I believe I should pass emissions no problem. Even without a cat I pass every test, except HC at idle, which makes sense. Thanks guys
sw20drift is offline   Reply With Quote
Old 03-24-2007, 11:05 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
2.5 sounds small. The primary is (was) 5" coming off the turbine. I think I would go as big as I could find to avoid as much restriction as possible.
The Jedi Speeder at CarDomain
Old 03-24-2007, 12:12 PM   #3 (permalink)
View jesse0880's Photo Gallery
can you pass with just the main cat and not the second (small) one? i actually need to get my car smoged so let me know how it goes.
jesse0880 is offline   Reply With Quote
Old 03-24-2007, 01:51 PM   #4 (permalink)
Hey MR2bad, the cat is gonna be located further along the exhaust system, basically where most mufflers are on our exhaust systems. The DP flange is about 5" like you say, but I'm gonna have the cat mounted with the exhaust piping, which is about 2.5". I have a factory primary cat, but I don't like dealing with taking my DP off and on, plus I want a high flow. I've heard many MR2s passing with the smaller 2nd converter Jesse, so with the primary in place and in good condition, you should pass with no problems.
Old 03-24-2007, 02:00 PM   #5 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
You won't pass visual in Cali if you are missing the secondary cat. If your car is in good condition you should pass everything else though. Visual is usually pretty easy to slide on at most places... but not technically "legal".
Old 03-25-2007, 11:24 AM   #6 (permalink)
Well, I just logged onto MR2OC, I cant access it from my pc in my office here where I am deployed. After reading a few threads it seems alot of users have had Random tech cats burn out on them and recommend the magnaflow/carsound high flow cats. Anyone have any personal experience or opinions on these cats. Some people say they outflow the Random tech. Sounds like a good deal, seeing that the Random tech costs about $250 and a magnaflow is about $100 or less. Any info will help, thanks.
Old 03-25-2007, 02:30 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
All the MagnaFlow products I've ever purchased were excellent not only in performance,flow and sound, but longevity too.
Especially for the price..
Old 04-01-2007, 11:45 PM   #8 (permalink)
^ Thanks MR2Bad, I think Magnaflow will be the way I go. Do you think it'll be too loud with just the High flow cat and the resonator from the HKS exhaust? I wanna be louder, but not illegal loud.
Old 04-02-2007, 12:41 AM   #9 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
same here.
i bought an OEM cat cause i didn't want my exhaust pipe screwed and chopped up then welded.
but everyone i know w/ high flo have no complaints and all have passed emissions
tHa kNiGHt FaLL is offline   Reply With Quote
Old 04-02-2007, 10:09 AM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
yeah, I think that would be pretty loud. It would prolly be OK where I live, but maybe illegal on the east coast.
Old 04-03-2007, 07:49 AM   #11 (permalink)
View keck03's Photo Gallery
i had a random tech cat on another car of mine. good but the engine was NA. still seemed like a lot of junk was then coming out of the exhaust. it flowed so well i took it off b/c i was getting headaches from driving the car with a full exhaust. i still dont think it was worth the money even though it was bolt-on in my application.
keck03 is offline   Reply With Quote
Old 04-15-2007, 02:16 PM   #12 (permalink)
Alright, thanks for the input so far guys. Now I'm just wondering, the Magnaflow cat has a Ceramic material honeycomb. From what I've heard if you are running too rich it will burn up a ceramic converter quickly. Now I'm running stock fuel and Ecu, should this really pose a problem? Also wondering, if my exhaust piping is 2.5" should I just get the 2.5" in/out cat or the larger 3" in/out cat to have welded on? Just want to prevent any loss of flow.
Old 04-15-2007, 06:04 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
If your DP is 3", you should go 3" all the way out.
Old 04-15-2007, 10:39 PM   #14 (permalink)
Downpipe is 3", but HKS Hi-power exhaust is 2.5"^
Old 04-15-2007, 10:52 PM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
is that a dual or single outlet?
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Buying A High Mileage Car? Your Opinions elvasoshexai General Discussion 21 03-06-2006 09:48 PM
hi flow cat Chico Camry & Solara Lounge 5 04-03-2003 10:46 PM
High flow Cat??? wontonjohnny Camry & Solara Lounge 10 12-10-2002 11:27 PM
high flow cat ? DrtySthV6SE Hardcore Tech and Competition 29 12-10-2002 04:57 PM
