tire sizes.??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2007, 12:05 AM   #1 (permalink)
View Eds1645's Photo Gallery
tire sizes.???
how come the rear tires are slightly larger than the fronts on a 2nd gen? can i just make all tires the same size. the 205/60/r14 . and also what are ur opinions on khumo tires?
Eds1645 is offline   Reply With Quote
Old 03-30-2007, 02:14 AM   #2 (permalink)
View sw20drift's Photo Gallery
The 2nd gens came staggered for a reason. I personally would not want to throw off this balance. You gotta figure, you need more rubber in the rear, all the weight and power is distributed there. Now, you can go for a same size setup all around, lots of people have done this, its just I personally like the staggered look and it makes more sense performance wise to me. If you're on the stock 14" rims, I don't believe you would be able to put 205s on the front, they are 6" wide compared to 7" in the rear. Go for aftermarket wheels or at least 93+ 15" rims. Havent heard much about Kumhos, I personally have had good experiences with Yokohama ES100s on my 14" rims, but now ride on Falken FK451s on 5zigen FN01RCs. Hope this helps a little.
sw20drift is offline   Reply With Quote
Old 03-30-2007, 07:02 AM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
for rwd setups....always better to run wider tires in the rears....kuhmo tires are garbage...spend the extra money and i would recommend Toyo T1-s or T1-rs....great in wet and dry...best tires IMO...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 03-30-2007, 11:06 PM   #4 (permalink)
well if i get directional. then i cant rotate my tires then. i think i might get michlen
Old 04-01-2007, 03:18 PM   #5 (permalink)
if you get staggered tires..you won't be able to rotate them either....
91 mr2..07 335i..
Old 04-01-2007, 11:34 PM   #6 (permalink)
^ true, but I dont think the MR2 is a car you wanna be cheap on tires with. That goes with all midship cars imo. Tires make the car, don't be cheap and you'll be safer too.
Old 04-02-2007, 12:43 AM   #7 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
most respectable performance tires are directional. but then again when you buy performance tires.
longevity isn't your highest concern
tHa kNiGHt FaLL is offline   Reply With Quote
Old 04-02-2007, 10:08 PM   #8 (permalink)
boost > vtec
View MRtuned's Photo Gallery
plus oversizing tires increases the risk of hydroplaning. yokohama makes excellent tires. Toyos are alse great, and probably better if you're just planning on driving a to b. if you don't like staggered wheels, get a different car.
gen 3 3SGTE swap, manual conversion, HKS Turbo exhaust, Blitz intake, TRD short throw shift kit, Autometer Boost gauge, OBX manual boost controller, Walbro 255lph fuel pump, 93+ rear suspension and subframe, Turbo model brakes
MRtuned is offline   Reply With Quote
tire discussion for 07 camry CamryXLE07 5th & 6th Generation (2002-2006 & 2007-2011) 4 02-13-2012 12:25 AM
tire sizes? white03taco 1st Generation (1995.5–2004) 2 01-15-2007 11:55 AM
Tire Sizes jsarratt 2nd Generation (2005+) 6 12-29-2006 02:47 PM
Need Urgent Help with Tire Sizes Paldente 2nd Generation (2005+) 3 03-28-2005 12:31 AM
Tire sizes SaintDanmic General Discussion 6 10-08-2004 07:06 AM
