^^^ "compression" has nothing to do with it...... the smallport with 10.3:1, the ST with 10.5:1 and the BT with 11.0:1 are all still non-interference......
non-interference simply means that with the valve fully open and the piston at TDC the two don't hit
however.... a 16V head shaved .15 or more could make it an interference motor.....
***edit*** however... I guess you could look at this another way..... a spit shim could cause a bent valve, causing the timing belt to break...... either way, make sure everything turns over nicely before you attempt to put it all back together
