Need a little help transmission wise... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2007, 08:12 PM   #1 (permalink)
View kragenkloud9000's Photo Gallery
I own a 1991 mr2 turbo which i recently swapped in a newer gen3 3sgte engine and tranny. But one day it gets stuck in 3rd...wont come out...sits parked for couple months...magicly comes out drives fine. Later gets worse like its wanting to stick in 3rd...so i avoid it all together (3rd gear) then reverse goes out...later comes right back magicly once again...then the sticky gear moves from 3rd to 4th. So i try avoiding 4th. Then on my way to the trans shop it completly locks up and is fucked because i shifted to 4th then tried going out...and it locked up and wouldnt really go into any gear w/o kicking itselfs out of gear again. So i drug it home with dolleys, and it starts working again but couple days later 3rd and 4th doesnt work...it grinds hard when trying to shift to those gears and it wont actualy go into 3rd or 4th, i let out on the clutch and it kicks it into nuetral while grinding...so all i have is 1st,2nd,5th, and reverse...all working fine....just wondering if anyone know wtf the problem is...Oh and today i just got my oil and gear oil changed (drained and refilled) but problem still exists...also does anyone know if they're anymore transmissions that are compatible to my engine i think a camry tranny might but not sure which...any help is appreciated.
kragenkloud9000 is offline   Reply With Quote
Old 04-05-2007, 08:53 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Shifter forks?
Old 04-06-2007, 12:46 AM   #3 (permalink)
boost > vtec
View MRtuned's Photo Gallery
the older gen 2 transmissions seemed to have a few problems with 3rd gear. idk if it was the syncros or what, but Toyota didn't do anything about it until 93. how many miles does the transmission have on it?
gen 3 3SGTE swap, manual conversion, HKS Turbo exhaust, Blitz intake, TRD short throw shift kit, Autometer Boost gauge, OBX manual boost controller, Walbro 255lph fuel pump, 93+ rear suspension and subframe, Turbo model brakes
MRtuned is offline   Reply With Quote
Old 04-06-2007, 02:11 PM   #4 (permalink)
My tranny should be a gen3, which is what engine/tranny swap was sent and installed...shouldnt have anymore than 70k on it
HELP: Serious Transmission Problems arcasmachineracing Camry & Solara Lounge 23 06-22-2008 11:53 PM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
odd transmission problem andyhowell Camry & Solara Lounge 3 10-31-2006 11:25 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
