I had the Eibachs put on the press (a machine the rates the stiffness of the spring) at my friends shop and they were much stiffer than the Tein's, which surprised me. The best ride I got out of the old set (Teins/KYB) was setting one. I was amazed, I assumed the stiffness of the Tein spring would be greater than the Eibach, but between the stiffness test and another test that rates bounce the Eibach had 1/3 the rebound rate of the Tein.You could visibly see the two in comparison, the Tein when given vertical input would rebound 6-7 time before settling, the Eibach on the other hand rebounded 2-3 times before settling.Anyways, all I know for sure is the Eibachs ride amazingly smooth and the car handles better in corners than before, on and off the track.This weekend I had the alignment set for the track (I did not put on my Mugen coil overs as I wanted to see the difference) and ran it 6-7 times around and was very pleased.I will still use my coil overs for track days as the height adjustment/caster/camber is much better, but would not hesitate to run it as is. Thanks for all the info..
