Originally Posted by MR2BAD
Sounds like a wire thats broken inside it's sheathing. Usually near where the door opens and closes causing the wire to bend back and forth causing the break.Vibrations, opening, closing, bumps, etc.,can make a connection for awhile then disconnecting again. it can drive you crazy. Hard to find because of that. Happens to door speakers alot too.
oh yea i had the pass side speaker that used to go out like that. when i went over bumps
it wasn't speaker wires cause i installed aftermarket wires, thicker through the loom because of the factory amp bypass bullshit. but a year and a half later and it went out all wierd when driving.
that one also fixed it self
