coolant Q? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2007, 12:24 AM   #1 (permalink)
View jesse0880's Photo Gallery
coolant Q?
my manual says not to use alcohol based coolant but i think that is what i used when i first rebuilt my motor. why is the alcohol based one bad? why does the manufacture call for the glycol based coolant and does it matter which kind is used?
and by the way... when i first start my car in the morning, the temp gauge begins to climb within the first minute of warming up. is that normal? my integra and ford escape both take way longer to warm up. whats the deal?
91 mr2 turbo
jesse0880 is offline   Reply With Quote
Old 04-30-2007, 07:25 PM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
yes it does matter. alcohol is corrosive if it dwells too long.
the gylcol is a lubricant and contains anti-corrosive attitives.
my MR2 warms up fast too. consider the rear engine design w/ your front mounted radiator as your answer.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 05-01-2007, 01:50 AM   #3 (permalink)
that makes sence about the warming up quick thing... i'm really concerned about having all the air out of the system though. recently i had to take off the throttle body so i know i introduced air into the system, but i'v been bleeding it out since. if there is air in the system, will it over heat automatically or will i be driving for a while and the temp will jump up out'a no where?
Old 05-01-2007, 02:29 AM   #4 (permalink)
boost > vtec
View MRtuned's Photo Gallery
how high does the temp gauge get? if it is normal after warmup, go for a short rip, boost it a little, and watch the temp gauge carefully. It shouldn't go much over half way.
gen 3 3SGTE swap, manual conversion, HKS Turbo exhaust, Blitz intake, TRD short throw shift kit, Autometer Boost gauge, OBX manual boost controller, Walbro 255lph fuel pump, 93+ rear suspension and subframe, Turbo model brakes
MRtuned is offline   Reply With Quote
Old 05-01-2007, 12:41 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I don't see how taking off the throttlebody introduces air into your cooling system....?
The Jedi Speeder at CarDomain
Old 05-01-2007, 01:23 PM   #6 (permalink)
Audi Technician
and if its not over heating i wouldn't worry about air in the system. i wouldn't really worry about anything at all
Old 05-01-2007, 08:01 PM   #7 (permalink)
it doesn't go any further than half way but i have never drove it over fifteen minutes or on the highway or anything. its not registered so i really dont wanna risk it.
i introduced air into the system when i took off the trottle body cause the water lines that runs to the ICS or whatever, i had to take off.
im only worrying about it cause i'v never driven an mr2 or a turbo'd sports car for that matter and i just wanna make sure everything is all good.
Old 05-02-2007, 12:45 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Hhhmmm? I've had to take off my throttle body several times for different reasons. I didn't have to remove ANY water lines. Anyway, drive the car around your neighborhood-staying close to home- for an hour. If it's gonna overheat, it'll do it then. But it doesn't sound like you have a overheating problem. This way IF it does overheat, you won't have far to get home. Maybe carry some extra distilled water-just in case..
Old 05-02-2007, 10:42 AM   #9 (permalink)
View keck03's Photo Gallery
that does sound a little fast for the warmup. i never boost for the first couple of minutes and my temp guage stays pegged at the bottom. if i do immed boost then it brings it up. i would even go as far as to say it warms up slower than my other cars.
keck03 is offline   Reply With Quote
Coolant loss 2005 Camry I4 winstead22 5th & 6th Generation (2002-2006 & 2007-2011) 2 01-29-2007 05:07 AM
1996 Camry radiator coolant disappearing? RAV4EVR 3rd & 4th Generation (1992–1996 & 1997–2001) 8 06-21-2006 12:13 AM
Brand of Coolant stir_fry_boy Camry & Solara Lounge 51 01-12-2006 10:45 AM
1997 Coolant & Differental question.. NorthernIllinoi Archived Corolla threads 6 10-25-2005 09:03 PM
TB Coolant bypass. CrawlingEye Camry & Solara Lounge 24 09-11-2004 11:03 PM
