Hey guys all great things must come to an end and i am sad to say that i have to sell my baby. I need to get the word out about my car. I would love ot sell it to another worthy and deserving person who knows and loves MR 2s but as we all know sometimes that isnt possible. Here is the laundry list of parts that i have put on the car.
93 T tops White
17k on motor 158k on chassis
Engine:
5SFE block Bored .20 over
3SGE head (converts to true dual overhead cam and lower compression)
Compression Ratio is 7.9:1 (capable of 32psi, I was going to do 28psi to be safe)
JE low Compression Pistions 88.5mm
JE piston Rings
Crower Connecting Rods
ARP rod bolts
ARP Head bolts
Apexi 2.2mm Thick metal head gasket
OBX Adjustable Cam gears
SFP Tubular turbo exhaust manifold
Greddy internal wastegate
Turbonetics T3/ T/4 ball bearing turbo (57intake 68exhaust)
3" in Custom Downpipe
Custom Exhaust
Custom Intake
Holley Fuel pressure regulator
Stock Intercooler
Blowoff valve
NGK Iridium Spark plugs
Brains:
Greddy E-Manage Ultimate
Greddy Turbo timer
MSD Bosst Timing Master
Turbo XS bual stage boost controller
Suspension:
91 3sgte Tranny
Spec stage 4 clutch (sprung holds 495ft/lbs trq)
Fidanza 12lb Flywheel
Turbo Hubs and axle
AGX Adustable Strusts
Eibach Pro kit Springs (1.0 front and rear)
Suspension Techniques Pollyurethane Bushings
Brembo Crossed Drilled slotted rotors
Interior:
D.A.D. Raceing seats
3 Point Harnesses
Autometer 2 gauge pod
Autometer Oil Boost A/F gauges (phantom series)
Reverse glow gauges
Sony Xplode CD player
Rollers:
TSW Kayilamis
17x8 215/35R17 front
18x8 244/40R18 Rear
Extras:
High volume fuel rail (supports 1000cc injectors top feed)
Walbro 255 lph fuel pump
3 Bar Map sensor
Sparco Carbon fiber pedal covers
For this car once yu add the injectors of your choice along with everything that has been done on the car it will run 28psi with no problem. I would have loved to be the one to do it but sadly things get in the way of our cars. Who ever buys it i would love to see in video of whatthe car can do on the 28psi. Thank you guys for the help you have given me in the past and i will stay on the forum to help others if i can. Thank you for helpig me get the word out about my car. good luck to all of you with your cars. Drive em like you stole em!!
