Originally Posted by jesse0880
true that man. i'm currenly running a geddy TD06 turbo. would it work well with the headwork and new cams? or would it not met the head's volumetric needs?
also- can the stock vavle train of the 3sgte be good enough for the hks 267's or do they need to be upgraded?
there is a very specific mathematical process you could do if you want the very best performance and find the best turbo for the motor your building.
i got all the formulas... but you need to get the CFM for the new build. I'd ask the machine shop. there are ways to calculate CFM... but i'd ask the shop so you can get it as accurate as possible. From there you can start mapping turbos to see which one will perform the best throughout the power band.
now cams... i'd think 267 would be a nice setup for a stock block and mild turbo. i would push something like a 278/276 type deal. and if you getting head work done i'd go over sized ferrai (sp?) valves.
cause at this point your pushing the abilities of building a nice race setup.
