Bummer ! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2007, 01:28 AM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Bummer !
Well, although I was correct about blowing the headgasket.(#2 cylinder), this is what I found when cleaning up the deck, piston tops.
Pitting on the left (intake) side of the piston. And what looks like a crack !
I am going to have to replace that piston and rings.. Darn ! and i was already to reassemble the engine...this is why you need to keep everything in check when pushing your engine hard. I can hear JekylandHyde's frequent cautions about detonation running thru my head...
The Jedi Speeder at CarDomain
Old 06-03-2007, 07:48 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Wow, that sucks.
At least you already have everything apart.
Good luck getting everything back together.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 06-03-2007, 11:48 AM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
^.. thanks Jeff.. I got it.. Just more time and money . I shouldn't complain tho. It's of my own stupid doing...and it could've been worse...
Old 06-10-2007, 09:05 PM   #4 (permalink)
View OEMonkey's Photo Gallery
Look on the bright side. They make nice paper weights or ashtrays.
Might want to look into pricing out a brand new short block fr Toyota. You may decide it might be worth it juxtaposed to just replacing a single piston.
OEMonkey is offline   Reply With Quote
Old 06-10-2007, 11:20 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
hhmm? I have a friend in the parts dept. at a Toyota dealer here and he's letting me have a new OEM piston, rings and wrist pin for $56.00. But I am going to re ring all 4 pistons.
Old 06-11-2007, 11:40 AM   #6 (permalink)
Rockin the STi
View onehotcamry's Photo Gallery
it's a blessing in disguise Russ. Your motor is telling you to build it up!
04 WRB STi - Stg. 2
93 White Mr2T - 263 rwhp @ 10psi
95 Black Mr2T - TKO exhaust
04 Suzuki GSX-R600
onehotcamry is offline   Reply With Quote
Old 06-11-2007, 02:22 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I might as well as long as I've got it this far apart.....^
Old 06-11-2007, 09:01 PM   #8 (permalink)
boost > vtec
View MRtuned's Photo Gallery
man that sucks. one of my fiends mixes 3 gallons ethanol with 7 gallons gas in his regal gs, so he gets higher octane. anyone tried that in an MR2 turbo? we can't get higher than 91 up here, I think he calculated it out to be around 97 octane with 3 gallons ethanol and 7 gallons of 89 octane.
gen 3 3SGTE swap, manual conversion, HKS Turbo exhaust, Blitz intake, TRD short throw shift kit, Autometer Boost gauge, OBX manual boost controller, Walbro 255lph fuel pump, 93+ rear suspension and subframe, Turbo model brakes
MRtuned is offline   Reply With Quote
Old 06-11-2007, 10:52 PM   #9 (permalink)
View CompanyFlow's Photo Gallery
It takes more ethanol to make the same amount of power as gasoline.
CompanyFlow is offline   Reply With Quote
Old 06-11-2007, 11:39 PM   #10 (permalink)
Rockin the STi
people use ethanol and alcohol injection for higher hp cars, but you don't really need to with mr2's as long as your using the best available octane rating.
04 WRB STi - Stg. 2
04 Suzuki GSX-R600
Old 06-12-2007, 10:03 PM   #11 (permalink)
boost > vtec
that depends. if you are detonating then you might not be making any power soon. lower octane is easier to burn than higher octane, but higher octane is less likely to allow detonation.
Old 06-20-2007, 11:04 PM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Well, I pulled the piston today. It was not cracked. I don't know what that funny line is. maybe a combination of oil and coolant that burned leaving that mark. But the pitting was enough to warrant a new piston. I took it to the shop to have the wrist pin pressed into the new piston onto the rod. I will pull the other 3 this weekend , cut what little ridge there is, hone it and ring it.
Old 06-21-2007, 08:22 AM   #13 (permalink)
Wasnt Me!!
View deuce93t's Photo Gallery
well that is a relief that it wast cracked. that could have led to some nasty things. good luck this weekend taking out the other pistions and ringing it. Yeah i would say that pitting would be enough to get me to buy a new piston, is still would think that you should replace all four. you got it open you might as well do it now to get rid of any doubt about the others. just my thought. get some pics of the fun project!!
deuce93t is offline   Reply With Quote
Old 06-21-2007, 08:31 AM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Naw, the other pistons are good. The Gasket only breached in that cylinder... Luckily.... Things could've been much worse...
Old 06-21-2007, 10:07 AM   #15 (permalink)
Wasnt Me!!
Yeah that is pretty lucky actually. I not to long ago had that same thing happen to mine only when it went it decided to take 3 of the four not just one. So i decided that JE pistions and Crower rods were in need and an apexi metal gasket. Well thanks to the car gods you got lucky
SUPER BUMMER on new black Helo wheels - Ah impatientce! cwhiley 2nd Generation (2005+) 33 12-15-2006 05:31 PM
Your Hummer is a real Bummer HoboJoe General Discussion 46 02-02-2006 08:00 PM
Cold Start Problem Camry100k Camry & Solara Lounge 15 11-07-2005 10:50 PM
Saying Hello I_am_Zman Introduce Yourself Here 8 05-20-2004 04:29 PM
bummer EKam Off Topic 7 09-02-2003 03:02 AM
