Oil Pan Gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2007, 12:50 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Oil Pan Gasket
Why in the hell does Toyota use a sealant for the 3sgte oil pan instead of a gasket?
Has anyone here made their own gasket in it's place? Seems like it would be alot easier. Especially during removal.(Rant)
The Jedi Speeder at CarDomain
Old 06-05-2007, 01:47 PM   #2 (permalink)
View toyomoho's Photo Gallery
Most likely the sealant has less leaks, easier to install/apply at factory, cheaper, might torque up better by having metal-to-metal contact.
Use Toyota FIPG sealer (some suggest the black stuff) or something similar. Pry off the pan carefully to not bend the flange. Once off, if required straighten the flange. Rockauto lists a pan gasket for this engine.
Old 06-05-2007, 02:08 PM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
dont break your oil level sensor...lol...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 06-05-2007, 05:07 PM   #4 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
i would use RTV Black before using the felt or paper type replacement gasket.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 06-05-2007, 11:17 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Yeah, I've been cautioned about that. So I have been very carefull in that area..
Old 06-05-2007, 11:21 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
It's got the black sealant on it. I bitch to get off. I ended up buying a thin bladed paint scraper to get in between the block and the pan without warping the pan edges. what a bitch.! that shit is stout...
What do you know of this gasket you speak of? Cork ?
Old 06-05-2007, 11:21 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Why is that Drew? and what do you think about the cork material?
Old 06-06-2007, 11:45 PM   #8 (permalink)
Audi Technician
the cork.... you kno... if its not torque properly it can get crushed so easily or not torqued enough and not created the right seal.
its what i have. i replaced my gasket w/ the cork type and i tapped every hole clean. pressure washed the pan and everything nice and clean. set the gasket and torqued in good rotation to specs and let silicone that came w/ the gasket cure for almost 5 hours and it leaked in less than 4 months. that was years ago and it still leaks cause i don't wanna do it again. when it becomes too much of an issue then i'll worry about it again. but i've changed 100's of oil pan/ gaskets and i've never had an issues w/ RTV black except its a pain to get off if your coming behind someone else who used it prior.
Old 06-06-2007, 11:48 PM   #9 (permalink)
Audi Technician
a rubber gasket is the best replacement gasket you can use for any component. when i feel like doing mine again i will search out one.
Old 06-07-2007, 12:10 AM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I hear ya on the cork. i guess that why you don't see then very much anymore. Except for the old school V8's
Thats a good idea. The valve cover and timing cover are both rubber. I wonder how that would hold up? And if they make sheets that you could make your own gasket from?
Old 06-07-2007, 11:40 AM   #11 (permalink)
rockauto lists a pan gasket for this engine.
Old 06-10-2007, 09:20 PM   #12 (permalink)
View OEMonkey's Photo Gallery
Fel Pro makes em for our cars. Part #MB91991 It's a cork gasket, have it on mine. No leaks. Cork gaskets are still widely used, especially on aftermarket A/T oil pan/filter kits. They won't leak if installed correctly.
OEMonkey is offline   Reply With Quote
Old 06-10-2007, 11:16 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
OK, thanks. I really prefer to go the gasket route....
Old 06-21-2007, 06:38 PM   #14 (permalink)
View sr5punk's Photo Gallery
wouldnt you be able to use a 3sge oil pan gasket? same block isnt it? or is the oil pan for both different?
sr5punk is offline   Reply With Quote
Old 06-21-2007, 11:43 PM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
hhmm? I don't know...... Anyone know if they are compatible????
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 09:00 AM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 03:17 PM
1990 N/A Auto :( dave_id Supra Forum 6 08-26-2004 12:18 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
Oil pan is off again! I need a leak proof gasket seal. Thoughts? bennington28 Hardcore Tech and Competition 2 01-25-2004 02:53 AM
