Typical BPU mr2 dyno power? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2007, 02:34 PM   #1 (permalink)
View problemmr2's Photo Gallery
Just wanted to see what your normal/average MR2 turbo will dyno with just exhaust, intake, and 16 psi?
Also, if i have a 255 walboro pump, and no FPR or bored fuel rail, will it be hurting performance? I just poped in a 255 walboro and didnt really do anything else figuring it would be ok.
problemmr2 is offline   Reply With Quote
Old 06-15-2007, 03:47 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
if you promise never to use BPU in a sentence with MR2 again, i'll take a stab at guessing...lol...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 06-15-2007, 04:44 PM   #3 (permalink)
Ummm.....sure.
Old 06-15-2007, 06:09 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
16 psi is pushing detonation with the CT26. The turbine itself is a restriction and just doesn't flow enough. And the higher flow fuel pump isn't gonna do you much good either without larger injectors. At best you would run rich.
I assume you're using some type of boost controller to up the boost from stock. I would guess 220-225hp at the fly with the increased boost from stock.
The Jedi Speeder at CarDomain
Old 06-17-2007, 06:46 PM   #5 (permalink)
i would think you might just make just over 200 to the wheels....
91 mr2..07 335i..
Old 06-18-2007, 07:42 AM   #6 (permalink)
View keck03's Photo Gallery
i have done this and didnt necessarily run rich. 550s on the stock ct26 is big-time overkill. i am guessing you did a NA-turbo swap and needed a fuel pump. you def shld look into a rail of some sort. the stock gen2 rail is poorly designed. wolfkatz did a test where it showed a walbro/supra pump exacerbates the lean condition that can occur on the one cylinder. either the ats bored rail ($100ish w/ core) or the wolfkatz rail will fix this.
i personally dyno'd with a similiar setup and put down around 205 iirc at the wheels. the dyno run showed way rch but after two years i finally found out why i was always rich: exhaust cam was off by two teeth.
keck03 is offline   Reply With Quote
Old 06-18-2007, 11:30 AM   #7 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
That is just one thing these pages are great for:
http://www.mr2ownersclub.com/mr2records/dyno1.htm
http://www.mr2ownersclub.com/mr2records/dyno2.htm
And if you are stock turbo, I would stay away from 16 psi.
I'd keep to 15 psi and under.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
MR2 (2000+) Bodykit Possibilities (feedback wanted!) GryphonAuto MR2 Forum 2 05-27-2006 02:08 AM
Dyno Power Services stood me up!!! I'm FUCKING PISSED OFF!! speedemn Feedback: Buyers, Sellers, and Vendors 9 10-03-2004 07:08 PM
