3S-GE / 3S-GTE for those of you interested in doing swaps...
3SGE / 3SGTE ENGINE SWAP
The 3SGE and 3SGTE are important engines in the Toyota line-up. They are the most potent of all the Toyota 4 cylinder engines in the 2000cc class. Celica, Camry, MR2, RAV4, and Corolla owners can benefit by upgrading to this engine.
For Celicas, Camrys, MR2s, and RAV4s- equipped with the 3S, 3SFE, 5SFE- engines the natural upgrade is the 3SGTE with horsepower ranging from 200 to 260 HP in the different generations. With minor bolt-on upgrades power up to 350 is attainable. Internally-built engines can produce up to 400 safely. The standard transmissions can be used quite effectively, but if you are planning running 12+ psi boost get the Turbo transmission..
For a milder set-ups the 3SGE may be adequate. Naturally aspirated the 3SGE is available from 140 to 200 HP. The 2nd generation (never imported to the US) produces 170 HP and are relatively cheap. Most parts for these engines are interchangeable with US engines, and is therefore easier to get parts for. The 3rd generation has 180 HP, and we support the unique parts for this engine. The 4th generation with VVTi has 200 HP, but is expensive and difficult to wire.
With such a wide choice of applicable engines, it is more the budget rather than HP availability that will determine your choice. Converting engines will require changing harness, ECU, AFM, related relays and igniters. No these are not legal in the US, unless you use US model engines (which limit you to the 1st generation 3SGE and 3SGTE, from the Celicas AllTracs, or the 2nd generation 3SGTE in the MR2s and AllTracs..
Japanese imported engines do not have EGRs- an important smog device required in US engines. It is impossible to modify a non-EGR head. Emission controls in Japan are stricter than the US, so technically they will pass tail-pipe emission tests, but they will fail any visual smog inspection.
Celica Notes: Any S engined Celica is relatively easy to do, if you have all the correct parts. Celicas with the A engines will require a new transmission, new engine brackets and new power steering and ac lines. For turbo, read the following MR2 notes. Stick with the 2nd generation engines as it has a built-in air-to-air intercooler. The 3rd generation engines have Liquid-to-Air intercooler and trying to set it up, you basically need a front clip.
MR2 Notes: Turbo conversions are best done using the 3SGTE, rather than turbo kits. 3SGTEs drop in easily with minor rewiring and the usual new resistors, igniters, and relays. You need the correct engine harness, ECU, and AFM. We normally stock complete conversion kits. Changing transmissions is not critical, but if you plan very heavy use go get the turbo transmission. This will require new axles, depending on the year model of the transmission, ABS, LSD, etc. The any generation 3SGE is a good substitute to the 5SFE, in fact in Japan it is the standard engine. For the ultimate- drop a 3SGTE in an AW11!
UPDATE: 3SGE and 3SGE installations for the AW11 is now a lot easier. Previously, we had to modify firewalls, brackets, etc. We have brackets and engine accessories that will make this all simple- with AC too !!!. Watch updates under Project Cars.
Corolla Notes: The 3SGE and 3SGTE engines have been installed in the FWD and RWD Corolla models. In RWD configuration, new intake and exhaust manifolds need to be fabricated or the original units reoriented, since these engines were originally designed and installed at an angle. See our list of RWD conversion parts- NOTE this is to fit the 3SGE or 3SGTE into a RWD chassis, not to convert cars to RWD. The only exception is the Altezza 3SGE Dual VVTi that came in RWD form only! In FWD, new brackets for the engine and transmission need to be fabricated.
These are general guidelines. We have no step-by-step instructions to do these conversions, since there are a lot of variables involved. Do not attempt if you are doing this conversion by yourself and feel you are not up to the task or your shop has never done one before. See the 3SGE / 3SGTE TECH NOTES also.
Here's the link:
http://toysport.com/webpages/Techinf...tech_notes.htm
