Oil Filter Relocation kits - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2007, 09:06 PM   #1 (permalink)
View K'tara's Photo Gallery
3rd Generation Oil Filter Relocation kits
What are your thoughts on one of these things? I've seen alot of people use them, but someone around here was talking about how their engine locked up after putting one on. He had the right amount of oil in the pan, but could it be that his oil pump couldnt handle pumping that extra few inches? To my knowledge the oil pump has never been changed, same with water pump and alot of his other stuff on his car. The thing ran great for 250k, until a week after putting it on, thanksgiving eve, the engine locked up.
I'm skeptical about a relocation kit after finding out about this, but I'm wondering how one will do on a newly built engine, like the 3sgte's. Cause I dont want to have a problem with the location of the filter and the custom downpipe I have to get made for my camry.
K'tara is offline   Reply With Quote
Old 06-30-2007, 12:53 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Avoid it if you can..
The Jedi Speeder at CarDomain
Old 06-30-2007, 12:58 AM   #3 (permalink)
View toyomoho's Photo Gallery
If you go this route get a system with a by-pass valve. If for some reason the remote filter system resistance becomes too great, the oil will by-pass the system.
Old 06-30-2007, 01:19 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
^ good idea. It can be done safely. It's just scarey if it fucks up-like when you're on the freeway doing 70 and 80 miles from home.
Old 06-30-2007, 01:32 AM   #5 (permalink)
BANNED
View w203's Photo Gallery
Well since we don't know where the location of the relocated oil unit is.... its hard to say. But not changing the oil/water pump is not a good idea. The oil should have no problem with pressure unless its mounted all the way up. Just add extra oil until it fills up the line.
w203 is offline   Reply With Quote
Old 06-30-2007, 01:45 PM   #6 (permalink)
mr2oogleX
View moogleX's Photo Gallery
we put one on my friends 325i, and an oil cooler. (with a turbo kit) it took a lot more oil, but we had no problems. I guess make sure its not in a place that would be bad for hight, access, heat etc and make sure its hooked up nice and tight with enough oil. A bypass valve couldn't hurt either
Originally Posted by Quandry
...Turbo's have vaccum too, it's just not the fun part of the gauge
moogleX is offline   Reply With Quote
Old 06-30-2007, 08:24 PM   #7 (permalink)
So, you're saying to add more oil if you use a relocation kit, right? How much more?
Old 07-01-2007, 12:59 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
You're just gonna have to check the dip stick. or the kit may tell you how much additional oil is needed.
Old 07-01-2007, 06:35 AM   #9 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Why do you think you want/need an oil fitler relocation kit?
If it's not broke, don't fix it.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 07-01-2007, 08:12 AM   #10 (permalink)
mr2oogleX
personal pref? maybe on some cars easier access? one does not NEED said product so i would guess one of those reasons as it does not give any performance upgrade.
we used a kit on my friends car cuz most of the stuff is custom done. only supercharger kits avail for bimmers. so the kit came in pretty handy plus they are cheap. thats always a plus lol
Old 07-01-2007, 06:57 PM   #11 (permalink)
that's basically it. I have to get a custom downpipe made, which may or may not get in the way of the filter. So, all I'm just doing is finding out before hand. You know?
Old 07-01-2007, 08:47 PM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I would only do it if it was absolutely neccessary. It's another possible place for an oil leak.
Old 07-02-2007, 08:34 AM   #13 (permalink)
yeah, I hear ya. I'm just keeping this in mind "if" the downpipe gets in the way.
Old 07-02-2007, 10:22 AM   #14 (permalink)
View keck03's Photo Gallery
i would take a pass on it. i seem to come across a lot of problems with them on the miata boards. the oem location is a major PITA so people switch them. i have seen at least one person blow their engine. for me thats enough to scare me away.
you shouldnt have a problem with one on a 3sgte with a downpipe. i have both and i just reach right down and take it off. prob the easiest car i have ever owned.
keck03 is offline   Reply With Quote
Old 07-02-2007, 03:41 PM   #15 (permalink)
yeah, I'm hoping I wont have a problem with the downpipe getting in the way cause I have to have it swing around because of that front motor mount on the camry.
2005 Toyota Tacoma oil filter part #? Billzebub 2nd Generation (2005+) 26 02-28-2006 02:41 PM
LESS MESS Oil Filter Replacement 73sport Camry & Solara Lounge 13 12-02-2005 09:34 PM
7Mgte oil filter relocation slacker Supra Forum 2 08-06-2005 09:41 AM
Oil Filter FrankXT86 Camry & Solara Lounge 4 11-10-2004 08:31 PM
Oil filter relocation and oil coolers Meisner Hardcore Tech and Competition 0 04-21-2002 03:44 PM
