Oil Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2007, 01:50 PM   #1 (permalink)
Rally_9RPM
redline_mr2's Avatar
View redline_mr2's Photo Gallery
Oil Leak
The last few days my car has been leaking a consitent oil leak not a ton or anything a small one. The leak is only when the car is running and maybe a few minutes after the car is off. I look at the front of my motor and the left side, nothing. Looked at my oil lines to my turbo and nothing either. I touched the passanger side and got nothing and the back and found nothing. It looks like the oil pan but doesn't fit the oil pan. Any ideas on places to look? I might do a uv die additive soon. Its dripping at the right rear corner on the oil pan. Whats the easiest way to remove the cam gear cover to check those items.
*Break For Honda*
"Trista" 422hp @ 15psi(Blown In Rebuild Stage)
redline_mr2 is offline   Reply With Quote
Old 07-01-2007, 06:28 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Oil return hose from turbo?
The Jedi Speeder at CarDomain
Old 07-01-2007, 08:25 PM   #3 (permalink)
Rally_9RPM
no I did not. Where is it located. I also checked under cam gear cover and found nothing.
*Break For Honda*
Old 07-01-2007, 08:43 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Follow the rubber hose from the front side of then oil pan up to the turbo. Just a guess since you haven't found a leak anywhere else.
Old 07-01-2007, 10:40 PM   #5 (permalink)
Rally_9RPM
I looked but nothing......
*Break For Honda*
Old 07-01-2007, 11:15 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Are you noticing a drop in oil level on the dip stick? Could it be gear oil?
Old 07-01-2007, 11:31 PM   #7 (permalink)
Rally_9RPM
not really its a small amount. I took it and sprayed down the whole motor and under and its little drip still. I call josh at chichorace works. He said there is a channel near there if oil leaks from the crankshaft seal it will run down the channel. But i could find that channel he was talking about.
*Break For Honda*
Old 07-02-2007, 11:31 PM   #8 (permalink)
Rally_9RPM
Could it be a rear main seal, front main seal or cam seal?
*Break For Honda*
Old 07-02-2007, 11:42 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I think if it was the front seal, it would be easy for you to find. If it was cam seal, it would leak from the same place on the timing cover.
Rear seal, would be the hardest to detect and the most pain in the ass to change...You would have to pull the transaxle, clutch and flywheel to replace the seal......PITA !
Old 07-03-2007, 01:11 AM   #10 (permalink)
Rally_9RPM
Well, I ordered all the parts cause they have to come out of town. I ordered the Front crank seal, rear main seal and the cam seals. I gave up and I'm taking the car into the shop to see. If it is the rear main seal, which I think so its only going to cost 240 dollars for labor and 40 dollars for the seal set.
*Break For Honda*
Oil leak - Help! bavula 3rd & 4th Generation (1992–1996 & 1997–2001) 6 04-22-2007 02:53 PM
Oil Leak when Accelerating??? renmike 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-08-2006 08:41 PM
1990 oil leak poorlady 1st & 2nd Generation (1983–1986 & 1987-1991) 7 08-29-2006 08:44 AM
oil leak! help! matrix37495 Tercel, Paseo, Starlet, and Sera Forum 7 05-28-2005 10:49 PM
Me and my oil leak -- help! jawhie Celica Forum 11 01-10-2005 09:51 AM
