Need Help W/Build - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2007, 12:33 AM   #1 (permalink)
Butters That's Me
View Boosted_SW22's Photo Gallery
Exclamation Need Help W/Build
oka i'm thinking of buying an MR2 once my insurance check comes in but i need some help with some stuff and want to ask you guys if i'm on the right track or not since i'm not much of a boost head.Well anyway here it goes.BTW i will be doing this before the 3S swap goes in.
Bottom End
Bored,Honed and sleeved .40 over
Arias Pistons 9.0 comp
Eagle H Rods
ACL Bearings
ARP Main Studs
ARP Head Studs
ARP Rod Bolts
New Water pump
New Timming Belt
Balanced and Blueprinted
Head
HKS 272 Cams
HKS Cam gears
Ferrea Oversize Valves
Ferrea Retainers and Springs
Port and Polish
3 angle valve job
Head milled for flat surface
Transmission
LSD
ACT Clutch
Fidanza Flywheel
Turbo
Greddy T78 Turbo kit w/external Wastegate
HKS SSQ Blowoff Valve
Intercooler
Spearco Intercooler
Fuel
HKS Fuel Rail
Walbro 255 Fuel Pump
Exhaust
Garage Fukui 3" Exhaust
Air Flow
K&N Intake
Turbo Acc
Greddy Turbo Timer
Greddy Timer Harness
Greddy Boost Controller
Greddy Boost Cut Defenser
Now for injectors i dont know what kind of cc i have to run and also what kind of fuel pressure regulator as well.As for the head would valve guides be neccessary?Now i saw hyde has an aftermakert intake manifold will i need to run one as well same goes with the throttle body?Also what kind of engine management should i be looking at?This car will mostly see track and typical weekend runs and i'm in no hurry whatsoever to finish it.I'm sure i miss some stuff so let me know if everything is good so far........
Boosted_SW22 is offline   Reply With Quote
Old 07-02-2007, 12:54 AM   #2 (permalink)
Rally_9RPM
redline_mr2's Avatar
View redline_mr2's Photo Gallery
For your ecu needs I strongly recommand the aem ems. It can do almost anything you can think of. I would say a dual top fed fuel rail. Run a strong 600 or 650cc primary injector and a secondary 1500cc or so injector to run your peak out. Aem has a pretty good fpr and might look at the trd fpr as well. Going to need a custom exhuast manifold for your turbo. Jeff is running a Ross Racing Intake Manifold. Wouldn't be a bad idea. I recommand the Apexi Boost controller over anything else. Everything else looks pretty could. Going to need to strengthen your suspension and brakes for the added power.
*Break For Honda*
"Trista" 422hp @ 15psi(Blown In Rebuild Stage)
redline_mr2 is offline   Reply With Quote
Old 07-02-2007, 11:59 PM   #3 (permalink)
Butters That's Me
what do u mean by 650 primary and 1500 for peak does it mean i need 2 different size injectors?sorry but i'm not that familiar with boost that much.Also what is the difference between the dual top feed u mentioned compared to the HKS got any pics of that fuel rail? or idea where i can find it?Also have a place or website for that intake manny?
Old 07-03-2007, 12:01 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
There are only 4 injectors. 1 doubles as a cold start injector.
The Jedi Speeder at CarDomain
Old 07-03-2007, 12:17 AM   #5 (permalink)
Butters That's Me
so 650 cc is reasonable then?Also where can i find intake manifold for the 3S turbo?
Old 07-03-2007, 12:27 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
It depends on how much horsepower you intend to make.
Truleo makes an intake for the 2. As do a couple of other companies. ATS racing may have some, Chicoraceworks too. You just gotta do your home work.
This is my Truleo that I'm going to install when I get to that point of my rebuild.
Old 07-03-2007, 01:30 AM   #7 (permalink)
Rally_9RPM
Depends on how crazy of an intake you want....
*Break For Honda*
Old 07-03-2007, 04:59 AM   #8 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
I'd suggest doing some reading here:
http://www.mrcontrols.com/primers/power.htm
I would not suggest doing a dual fuel rail set up.
A single rail, with 1000 ccs will be more than enough to get you to 600 rwhp.
I would talk to Garrett at Wolfkatz Racing about building a proper fuel system for your goals.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 07-03-2007, 06:30 AM   #9 (permalink)
Butters That's Me
that site helped out a lot.Now i have a better idea of what to do.
