260-300 rwhp goal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2007, 01:09 AM   #1 (permalink)
Fly High
AREAGANO's Avatar
View AREAGANO's Photo Gallery
2nd Generation 260-300 rwhp goal
Hey all, I am getting my mr2 swapped with a jdm 2nd gen motor complete with turbo, intercooler, fuel pump, harness, and ecu, it will also will be fitted with custom 3" downpipe, apexi N1 exhaust, greddy profec b spec II bc.. i assume at this point that at 12 psi (from what i read that is the max boost i can use without cutting a vacuum line to disable the boost/fuel cut right??) Soo, from what i've been reading i should be somewhere near 200 rwhp when I pick the car up. I was wondering what your suggestions are for reaching a RELIABLE 260-300 rwhp daily driver.
....And the blacks choose ...TIGER WOODS!
Thank you, Thank you,
I've always wanted to say this ....fer shizzel.
-Hit me up on Forza2- XBOX360 GAMERTAG: AREAGANO
AREAGANO is offline   Reply With Quote
Old 07-03-2007, 01:20 AM   #2 (permalink)
Rally_9RPM
redline_mr2's Avatar
View redline_mr2's Photo Gallery
There are several things you can do to make that better. First thing I would to is get some gauges like oil pressure, af ratio gauge, water temp. Next I would buy a after market ecu like a aem ems my personal choice, plug in play use everything do just about everything. Also get little bigger injectors, a fuel rail, fpr. Then interals can take little more boost so your okay. You could buy intake and exhuast, got to breathe to make more horsepower. Get a t3/t4 turbo, different cams. With this setup you can create more horsepower than what you ask for.
*Break For Honda*
"Trista" 422hp @ 15psi(Blown In Rebuild Stage)
redline_mr2 is offline   Reply With Quote
Old 07-03-2007, 04:55 AM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
http://www.mrcontrols.com/primers/power.htm
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 07-03-2007, 12:26 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
^ read the link Jeff posted for you. For little $$$ you can get to 280hp. After that you will need a stronger clutch.
The stock internals are good to 400hp. Jeff's MR2-Hyde- is living proof of that.
The T3/T4 will easily get you the HP you're looking for with fuel enhancements(fpr,fuel pump, larger injectors) and the stock cams. You will need some type of engine management.
The Jedi Speeder at CarDomain
Old 07-03-2007, 02:28 PM   #5 (permalink)
Rockin the STi
View onehotcamry's Photo Gallery
i dynoed 263 rwhp @ 10 psi. ( http://img293.imageshack.us/img293/7...rper011sx3.jpg ) I have different pistons and all, but do not really need them. They were just installed when my motor went the first time.
For the goal you are looking for I would seriously consider a ATS turbo kit. The TD05 (what I have) or the TD06 would easily put you around your goal safely.
here's my mod list
ATS TD05 20g Turbo Kit
ATS 550cc rom tune
ATS modified fule rail
Walbro 255hp fuel pump
170 degree thermostat
550cc fuel injectors
Apexi GT Spec Exhaust
Apexi intake
Greddy TT
Greddy Profec B (not hooked up)
Spec Stage II clutch
Fidanza Flywheel
ATS Racing Throttle Body Inlet
Eagle Rods
ARP Rod Bolts
JE Pistons (.20 over)
the kit ATS offers comes with the majority of that stuff.
www.atsracing.net
04 WRB STi - Stg. 2
93 White Mr2T - 263 rwhp @ 10psi
95 Black Mr2T - TKO exhaust
04 Suzuki GSX-R600
onehotcamry is offline   Reply With Quote
Old 07-04-2007, 06:26 AM   #6 (permalink)
I love Cin
MR2BAD, he linked to the dyno graph in the first sentence
Old 07-04-2007, 10:38 AM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
ooops! Well, Duh? Thats embaressing....... Never Mind Joel
Old 07-04-2007, 12:09 PM   #8 (permalink)
Rockin the STi
guess i missed something haha
04 WRB STi - Stg. 2
04 Suzuki GSX-R600
Old 07-04-2007, 12:52 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I had asked you for the dynograph not seeing it in the very 1st line of your post. Duh ! Anyway, I deleted it.
Impressive numbers. Especially for 10 psi... I'm thinking of going that route on my rebuild. I have heard nothing but good things about ATS. And they know MR2's very well. And I believe them to be trustworthy and honorable company.
Old 07-04-2007, 01:04 PM   #10 (permalink)
boost > vtec
View MRtuned's Photo Gallery
or you could get a gen 3 clip and put an exhaust, intake, IC, and BC on it. there ya go, mid 12's.
gen 3 3SGTE swap, manual conversion, HKS Turbo exhaust, Blitz intake, TRD short throw shift kit, Autometer Boost gauge, OBX manual boost controller, Walbro 255lph fuel pump, 93+ rear suspension and subframe, Turbo model brakes
MRtuned is offline   Reply With Quote
Old 07-04-2007, 01:11 PM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I think I prefer to stick with 2nd gen USDM. Besides, I have already honed and ringed the pistons/block.
Old 07-04-2007, 01:16 PM   #12 (permalink)
boost > vtec
yea, I was just saying its not hard to get power out of the gen 3, its like a gen 2 with a turbo kit from toyota. I have a gen 3 clip on the way . how is your build going?
Old 07-04-2007, 01:24 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
It's going...Time and money are the only hold ups. I work full time and money has been scarce the past year. I'm prolly gonna get rid of the Spyder. It's getting to be a pain keeping up with 3 vehicles. Insurance, gas, maintainance and all. I don't drive it that much. I use my Tacoma alot.
Old 07-04-2007, 03:36 PM   #14 (permalink)
Rockin the STi
gen 3s are a waste of money if you're thinking of seriously modifying your mr2
04 WRB STi - Stg. 2
04 Suzuki GSX-R600
Old 07-05-2007, 06:25 PM   #15 (permalink)
boost > vtec
its newer technology. a better IM, turbo, injectors, etc. yes, I know if I am shooting for over 350 whp its a waste of money since I'm going to be replacing all of that anyway. I dont care. the difference is that I'll have that much power now. This is about all the money I can afford to spend on this car for the next 3 or 4 years, so I wouldn't have been able to really rip into a gen 2 to get it to where I'm going. I only want 300 whp right now. If I want more later, I'll just sell all the gen 3 stuff. that, and almost every single person I've talked to, or read posts by that has done the gen 2 swap wishes they would have waited and saved for the gen 3. it is far easier to get to 300 hp, and if I have more power I would start breaking things and just getting into crashes or trouble. that and the gen 2 is inferior in every way (if only slightly), so I just didn't see the point.
Lexus History BLUEMEANIE General Lexus Discussion 8 11-25-2011 12:53 PM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
List of V6 5-Speed Camry's I found currently for sale ASG14 Camry & Solara Lounge 13 10-22-2006 05:59 AM
440 RWHP: NoShoes Tuned, ATS Sponsored, Herstine built Hyde JekylandHyde MR2 Forum 25 08-24-2005 08:47 AM
New Sportdesign Is 300 And Gs 300 CDNVITZ General Discussion 12 04-07-2003 12:13 AM
