Spark plug for 3sgte - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2007, 10:22 PM   #1 (permalink)
ryde's Avatar
View ryde's Photo Gallery
I forgot which NGK plug most people suggest to run in the 2nd gen 3sgte. Also what gap should I run? Thanks for the help.
ryde is offline   Reply With Quote
Old 07-06-2007, 12:01 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
BK6E or BKR6E (resistor type if needed)Stock #6962
Gap depends on Turbo boost. .030 is standard
The Jedi Speeder at CarDomain
Old 07-06-2007, 02:49 PM   #3 (permalink)
View keck03's Photo Gallery
if you are running higher than stock boost
run bkr7e (1 step colder) and gap it closer. my car seems to like .028. any larger and i get some stumbling.
keck03 is offline   Reply With Quote
Old 07-06-2007, 10:44 PM   #4 (permalink)
ryde's Avatar
So is everybody still against iridium?
Old 07-07-2007, 12:43 AM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
The Iridium plugs have a tiny tip. I have heard that thay may melt off at higher boost levels. I didn't want to take the chance. So I pulled them . I use either the NGK coppers or Platinum. Way cheaper too.
Old 07-09-2007, 07:43 AM   #6 (permalink)
my engine seems to respond well to fresh plugs. the coppers cost me around $10 and 10 min of my time. never had a problem other than the one time i didnt regap them.
Old 07-09-2007, 12:08 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
$10.00 ! I pay $1.87/ea from O'Reileys
Old 07-09-2007, 12:45 PM   #8 (permalink)
i also pay the $1 for the anti-seize and $1 for the other grease. i know its prob not necessary but piece of mind is worth $2. i had to take out stuck plugs once and it was scary.
Old 07-09-2007, 01:02 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I always use anti seize. That can be scarey
Old 07-10-2007, 10:26 AM   #10 (permalink)
Wasnt Me!!
View deuce93t's Photo Gallery
I have used the iridiums and havent had a problem. Then again i am running 18psi and not a high amount of boost like is said to burn the tip off. As well though if they burn the tip off the plugs do come with a one or 3 year warentee with them so if it ever did happen then they just replace them anyways. I will have to check out the NGKs like you guys say though and see how it runs
deuce93t is offline   Reply With Quote
Old 07-10-2007, 12:28 PM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
If the tip of the Iridium plug melts off, new plug replacement will be the least of your problems. The metal can melt a hole thru the piston and you will prolly need major engine work.
Old 07-10-2007, 12:34 PM   #12 (permalink)
Wasnt Me!!
lol yeah that is a good call totally slipped my mind! i think a whole in the piston would be a little bit more of a problem then replacing the spark plugs i will check out those other plugs.
Old 07-10-2007, 12:39 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
The NGK coppers are good. Especially for the price. But they have to be changed about 3600 miles. usually with the oil change.
Old 07-10-2007, 02:33 PM   #14 (permalink)
Wasnt Me!!
yeha but for as cheap as they are that isnt to bad its better then paying 35 for the iridiums.
Old 07-11-2007, 11:38 AM   #15 (permalink)
+1
i prob even change them sooner since i swap for each trip to the dyno or dragstrip. i also like the fact that the plugs give me an idea of how the car is running on a more regular basis.
Spark Plug Port Damage jjtrev 1st Generation (1995.5–2004) 8 04-21-2009 07:16 PM
Oil leaking into spark plug tube, need help! nogard 3rd & 4th Generation (1992–1996 & 1997–2001) 7 06-30-2007 05:06 PM
Help!! Removing stuck spark plug in Camry 2.2 skewe Camry & Solara Lounge 23 06-04-2007 05:45 PM
okay to tighten spark plug tubes (valve cover is off)? 97&02camryleI4 Camry & Solara Lounge 4 07-10-2006 02:12 AM
How to remove a broken spark plug on my '93 Camry LE V6? Vibroseis General Discussion 4 03-03-2006 03:47 PM
