First Post here. I've searched extensively (here, and google), and can't find what I need to fix this.
The car:
89 MR2, 1.6NA, 5SP. 220,000 miles on original engine/transmission. 100% stock, except for custom wheels.
The issue:
About a week ago, my high beams died. Haven't changed anything wiring related, and haven't made any mods. It's 100% stock, and wasn't torn up when I got it, so I just keep the fuel in it, and drive...
The headlights pop-up and go down properly, and the low beams work. However, when I switch the high beams on, the headlights die completely until I switch back to low. When I try to use the flash-to-pass option with the headlights already on, they just turn off when I've got the switch pulled forward. If the headlights are down, and I pull the switch for flash-to-pass, the headlights pop-up, but don't turn on. OF COURSE, it does this just as I'm trying to get a new inspection sticker! DOH!
On the fuse block under the front hood, there is the relay that sits closest to the spare tire. If I turn the lights off, and back on before they close I can hear that relay open and close when I turn the lights on and off, but it doesn't change at all when I turn on the high-beams.
What I've done so far:
1.) Removed covers and tested voltage at the headlight plugs. I get 12 volts to the low beam terminal until I turn on high-beams, and nothing to the high beam terminal. When I change the switch to high-beam, I get no voltage to either contact. The wiring looks to be intact, and there are no other strange electrical issues up there.
2.) Pulled steering wheel, inspected combo switch, and wiring leading up to it. All features of the switch work, except for the high beam selection. Wiring all looks good. When you pull the switch forward, the lights pop-up, but they aren't lit. It looks like the cruise control and blinker/high beam switch are all part of one big assembly, and the cruise control also works. The fact that all of the things attached to the steering column work makes me think I've got good ground, etc.
Thoughts, Questions, Etc:
1.) I'm contemplating a toggle switch with 10g wiring inside the car, placed where the fog light switch normally is (I don't have fog lights), and using it to turn the high-beam side of the light on/off, but given the 100% stock nature of the car, I'd rather not do this. However, if I do, is there a danger in turning the high beam on, and leaving the low beam on at the same time?
2.) Is there another relay I'm not seeing that controls the low beam to high beam change?
3.) Anyone else seen this issue? How did you fix?
Thanks for reading! Hopefully this is something that I can get help with...
