oxygen sensor code 1155 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2007, 06:52 AM   #1 (permalink)
View stagescott's Photo Gallery
heated oxygen sensor circuit, bank 2 circuit 1 has been activated...how to I repair this problem.Just change the sensor? Is this the sensor closest to the rear of the engine? Please help this DIYer...
stagescott is offline   Reply With Quote
Old 07-17-2007, 12:58 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
IF this is a Turbo model-It's the sensor on exhaust side of the turbo. remove the 2 nuts and unplug it. The connector plug is near the IC fan. be carefull not to damage the O2 sensor gasket. They can be kinda brittle.
The Jedi Speeder at CarDomain
Old 07-17-2007, 02:01 PM   #3 (permalink)
Noob :-)
View ST185's Photo Gallery
What year is your car? MRS?
P1155 = heat circuit malfunction of bank 1 sensor 2.
You have a 4 cyl, there is no bank 2.
Sensor 2 is located downstream of sensor 1.
This would be the after-catalytic converter sensor.
93 ST185
ST185 is offline   Reply With Quote
Old 07-17-2007, 06:14 PM   #4 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
yea............ but they like to call the downstream sensor bank 2... it doesn't make sense really when banks refer to even and odd sides of the motor
tHa kNiGHt FaLL is offline   Reply With Quote
Old 07-17-2007, 08:56 PM   #5 (permalink)
View OEMonkey's Photo Gallery
Correct, that's the most common failure(heater code) on these A/F sensors fr Toyota. Just replace the sensor. If you wanna diagnose it first, that's easily done as well. Just check for open circuit voltage on the heater circuit KOEO.
On the MK III MR2, there are 2 pre-cat HO2S (or A/F Sensors for ca. emission cert. cars.) There's 1 closer to the driverside( for cyl 4&3), and 1 closer to the pass. side( for cyl 2&1.) I forgot which one is B2, S1. Both are equally easy to replace. BTW, the post cat sensor is B1,S2.
OEMonkey is offline   Reply With Quote
Old 07-18-2007, 07:54 AM   #6 (permalink)
obd code1155
Thanks guys... I have a 2001 NON Turbo MR2...(All stock) So I guess I just replace the sensor and all will be fine...
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
1993 Toyota Pick-up Oxygen Sensor Wiring Shawn1977 89-95 Toyota Pickup/Hilux 3 05-11-2011 10:10 AM
Replacing Oxygen Sensor For corolla 98 1998corolla1998 Archived Corolla threads 13 07-05-2010 11:35 AM
Oxygen Sensor wire omegarex Camry & Solara Lounge 0 04-23-2006 10:57 PM
Oxygen Sensor/CEL rockyoyster 89-95 Toyota Pickup/Hilux 3 04-09-2006 09:08 PM
