91 N/A Engine Idle Gallop - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2007, 09:21 PM   #1 (permalink)
MR2 Illusion's Avatar
View MR2 Illusion's Photo Gallery
I've had my 91 N/A MR2 for 3 years now, and I've always had the same problem. It idles at 1500 rpms when it's warm. When it's cold, my idle gallops in rhythm from 1000 rpms to 2000 rpms. As it warms up, the rhythm gets faster. I've checked and cleaned my intake tube and filter, my throttle body, adjusted the idle screw, replace the vacuum lines, and I'm running out of ideas. Could it be my EGR? Can I remove the EGR and put on a block off plate? Thanks!
MR2 Illusion is offline   Reply With Quote
Old 07-17-2007, 10:04 PM   #2 (permalink)
View OEMonkey's Photo Gallery
It's not the EGR. A stuck closed EGR won't affect idle, a stuck open EGR valve will lower idle rpm or stall or cause a no-start. Fluctuating idle rpm is caused most of the time by the ff: defective ISC valve, air in the cooling system, defective ECT, exhaust leak before the o2sensor( will affect idle only after closed loop ), and I'm sure there's more (others will chime in.)
OEMonkey is offline   Reply With Quote
Old 07-18-2007, 07:07 PM   #3 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
yea... vacuum leaks... throttle cable.
i've had this same issue... i took apart my ISC and cleaned it. there was all kinds of dirt in there making the valve stick.
then it happened again... and this time the throttle cable actually frayed inside the tubing and would stretch out. and i would have never known, well untill the cable broke.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 07-18-2007, 09:44 PM   #4 (permalink)
RideMr2's Avatar
View RideMr2's Photo Gallery
I had this problem, then I replaced and adjusted my TPS(right behind throttle body, 2 screws).
91 MR2 5sfe
03 Grand Am 2.2L Ecotec
RideMr2 is offline   Reply With Quote
Old 07-22-2007, 12:06 PM   #5 (permalink)
Thank you everyone for your help. I'll try your suggestions and see if anything works!
Does your engine make this sound when cold? montreal 9th Generation (2003-2008) 69 05-05-2009 08:10 PM
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Tercel 43fte engine swap, won't run right farmermoose Tercel, Paseo, Starlet, and Sera Forum 1 09-19-2006 09:28 PM
'91 MR2 Engine in a '90 GT-S Celica? Flea420 MR2 Forum 3 02-05-2004 08:56 PM
