Timing Belt Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2007, 01:02 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Timing Belt Install
Is there some kinda trick to getting a new timing belt over all the pulley's ?
The Jedi Speeder at CarDomain
Old 08-17-2007, 12:01 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
No one here has replaced their own timing belt ?
Old 08-17-2007, 01:16 AM   #3 (permalink)
View WT Morgan's Photo Gallery
Typically I put the belt over all the toothed pulleys (crank pulley first, cam pulleys last) and then slide the belt over the smooth adjusting idler pulley. I replace the idler pulley/bearing while I'm in there. With the idler pulley loose it allows for slipping the belt over the edge. Then snug it down, make sure the belt is all the way on the pulley, tension it and tighten it.
WT Morgan is offline   Reply With Quote
Old 08-17-2007, 01:46 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Thanks Morgan. I'll try that.
Old 08-19-2007, 10:11 PM   #5 (permalink)
View OEMonkey's Photo Gallery
Just finished replacing the head bolts w/ studs last week. Slip the belt last on the Idler pulley (as previously mentioned) make sure cam & crank timing marks line up before pulling the grenade pin on the hydro tensioner.
OEMonkey is offline   Reply With Quote
Old 08-20-2007, 12:45 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Yeah, I got it on. Thanks guys...
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 166 04-09-2012 10:44 PM
Timing Belt Slaps! kamrhee 3rd & 4th Generation (1992–1996 & 1997–2001) 13 07-13-2007 12:27 PM
Please help me with 92 V6 timing belt install snelson 89-95 Toyota Pickup/Hilux 10 05-17-2007 03:06 AM
GPS Antenna Location on Gen 6 hybridamp 5th & 6th Generation (2002-2006 & 2007-2011) 2 08-30-2006 12:13 PM
