Engine Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2007, 08:31 PM   #1 (permalink)
View MeWantMR2's Photo Gallery
2nd Generation Engine Problems
First of all any input on this thread would be very helpful. I have a 91 turbo mr2 with the following problem. If driven at half throttle it runs fine, but if you go into full throttle the engine becomes very uneven and choppy(sputtery). This occurs throughout the RPM band. Has been checked for boost leaks, has none.
Here are a few visible problems.
1. When the engine was hooked up after a clutch replacement some of the emissions control/vacuum lines were removed.
2. The AFM had sealant on the top as if had been removed and replaced.
I have done a little reading, here are my thoughts on the possible sources of the problem:
1. The AFM due to previously mention reason
2. The dealership techs said the timing belts were slipping
3. Malfunction in the boost control system such as the T/VSV.
4. Bad distributor contact
5. Clogged fuel filter.
Please let me know what you think, I really want to drive this car.
Thanks, Ryan
MeWantMR2 is offline   Reply With Quote
Old 08-30-2007, 11:14 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
All those scenarios could be the source of the problem.But given that the AFM has been messed with, that would be the 1st thing on my list to check out. No one should ever open them up.If it's been damaged, it will have to be replaced. A used one will do or buy a expensive Engine Management system.
If your timing belt was " slipping", it would already be way off time and you would prolly be smacking a piston top with a valve by now.
The TVIS vacuum valve can be tested. Use the on line BGB sticky in this forum to do so. Check to see that the vacuum line is not breached/leaking/damaged. That valve keeps those flaps open all the way to let in more air at higher RPM's.
I would think that a bad contact in the distributor would show up on a diagnostic without doubt.
A clogged fuel filter could do some of this. Just change it.Especially if it hasn't been changed in a long time. It's inexpensive and simple to do. Then that possiblity will be illiminated
The Jedi Speeder at CarDomain
Old 08-31-2007, 08:32 AM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
replace your ignition components (cap/rotor/wires)...that stuttering could be an exhaust leak also...i had the same problem with mine and had to re-surface the stock manifold....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 08-31-2007, 05:26 PM   #4 (permalink)
View WT Morgan's Photo Gallery
I ditto the cap and rotor as the first approach. It's quick and easy. If that doesn't work, go farther, but those are classic symptoms for a cracked cap or rotor.
WT Morgan is offline   Reply With Quote
Old 09-01-2007, 02:08 PM   #5 (permalink)
Thnks guys, i'm going to try to replace the rotor and cap and let you know what happens.
Ryan
Old 09-04-2007, 11:58 AM   #6 (permalink)
Just a thought. From my understanding the distributor is directly related to the engine speed, so if I’m driving and punch the accelerator it starts to shudder instantly, not once the RPMs climb. If the distributor was the problem it would only do this in high RPMs.Let me know what you guy think.
Thanks, Ryan
Old 09-04-2007, 12:32 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
If you're not getting good spark, you're not gonna get good fuel ignition. RPM,s will not climb very fast or at all if ignition componenbts are that bad.
Old 09-09-2007, 02:02 PM   #8 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
Thanks, Ryan
the RPM pickup is in your distributor housing. so in that it is directly related to RPM... but if you weren't getting an RPM signal your car wouldn't start.
i would definately lean away from the distributor as your problem.
i'd be checking TPS... Boost Sensor, VAF meter... pretty much the load sensing side of the house that dictates fuel delivery
tHa kNiGHt FaLL is offline   Reply With Quote
Old 09-10-2007, 09:03 PM   #9 (permalink)
Under acceleration a cracked distributor cap will cause a sputtering/popping/hesitation. It can be strong sometimes and non-existent at other times. It will usually get worse over time. A new cap/rotor costs less than twenty bucks, so it is easy to eliminate as a possibility. The cap could even be tight-wrapped with tape to compress/hold the possible crack as a zero-cost (although not ideal) way to see if it makes a difference and possibly eliminate it as a problem. The rotor is a definate replacement part.
I would still start here and then move forward.
Definately let us know what you find.
Old 09-12-2007, 11:23 AM   #10 (permalink)
I definately will keep you informed on what happens. Youll have to be patient with me I'm busy with school and work, but i will try to do something soon.
Thanks guys, Ryan
Old 09-18-2007, 08:51 PM   #11 (permalink)
So I drove the car on saturday and found that the bogging down was not a gradual fade as you step on the gas, but almost instantanious at a certain position it the throttle. My brother said it might br a throttle position sensor. Also the CEL was on, Are there any threads on here that explain how to read the engine code, and a list of what they mean?
Thanks again guys, Ryan
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
2000 camry engine problems help? LONG jotka 3rd & 4th Generation (1992–1996 & 1997–2001) 10 03-24-2006 10:16 PM
engine problems while on highway MR2Enthuze MR2 Forum 1 12-24-2005 02:04 PM
