T-VIS hose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2007, 02:08 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
T-VIS hose
Anyone know where the other end of this hose goes ? T-VIS
'91 MR2 Turbo 3sgte
The Jedi Speeder at CarDomain
Old 09-18-2007, 06:17 PM   #2 (permalink)
Beep Beep ~~~
NovaStorm's Avatar
View NovaStorm's Photo Gallery
Not sure this will help, Take a look here ~ http://www.mr2-tech.com/bgb/mechanic..._system/19.htm
and here http://www.mr2-tech.com/bgb/mechanical/volume1/efi_system/26.htm
It's not very clear for the 3s-gte
NovaStorm is offline   Reply With Quote
Old 09-18-2007, 11:40 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Yeah, it doesn't show where that hose goes.. I thought it should connect to intake manifold. But there isn't a open nipple for it.. idunno ???
Thanks though...
Old 09-19-2007, 01:36 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Old 09-20-2007, 10:10 PM   #5 (permalink)
View CompanyFlow's Photo Gallery
CompanyFlow is offline   Reply With Quote
Old 09-22-2007, 12:33 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Bump...
Old 09-22-2007, 02:12 AM   #7 (permalink)
View OEMonkey's Photo Gallery
that hose connects to the intake manifold. the nipple is facing towards the outside of the vehicle (driverside of course), not down or up. its' on the last runner(cyl. 4) of the manifold. it's close to last fastener (nut) of the manifold. it's almost directly under the fpr. maybe the reason why you don't see it is bec. you have another vac hose currently connected(wrongly) to that nipple.
OEMonkey is offline   Reply With Quote
Old 09-22-2007, 11:54 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
^ Thanks .. I was hoping you was answer this one. There was the empty nipple right where you said it was. thanks again...
Old 09-30-2007, 07:55 PM   #9 (permalink)
You're welcome. How's the car running?
Old 09-30-2007, 08:02 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I just finished reassemblt today. I still have to fill the crankcase with oil, fill with coolant and a new set of plugs. We shall see.
installing oil pressure gauge help atobe Camry & Solara Lounge 23 09-18-2011 04:02 PM
Power Steering Pressure Hose [2VZ-FE] monito 1st & 2nd Generation (1983–1986 & 1987-1991) 27 01-23-2010 03:12 PM
What do you think: Bad hose or bad radiator? luiscolorado 3rd & 4th Generation (1992–1996 & 1997–2001) 4 02-08-2007 01:58 PM
turbo abew330 Supra Forum 0 02-07-2007 05:51 PM
Radiator Hose help. SubaruWRXMike Archived Corolla threads 9 05-06-2005 04:46 PM
