Need help? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2007, 12:53 AM   #1 (permalink)
View pinoyboi2006's Photo Gallery
2nd Generation Need help?
Hey everyone I have a problem with my 93 mr2 turbo. I want to know how can you tell when you will need to rebuild your turbo.
Today i noticed something different with my car and i dont think its good. When I am driving and on a gear and reach around 4-5rpm my car seems to like cut out or boggle or however you say it and the bov goes off even though im still on the gas. Plus it seems like the turbo is spooling up much earlier because it use to spool up at 2500rpm and now it seems like its spooling up somewhere around 2000rpm. I was wondering if anyone has had this problem and help me out... Thanks
pinoyboi2006 is offline   Reply With Quote
Old 10-03-2007, 01:39 AM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
I would replace all of your ignition components first. Spark plugs, plug wires, distributor rotor and cap. 3SGTE's have a tendency to eat through ignition parts.
Old 10-09-2007, 01:09 AM   #3 (permalink)
I changed all the ignition components and still the same thing. my cousin told me that when he was driving behind me and my car started cutting out he saw a little bit of black smoke coming out...any ideas of what the problem could be?
Old 10-09-2007, 01:33 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Your BOV could be failing...releasing compressed air before it reaches the throttlebody. The AFM has already sent the signal/fuel for the measured air and the engine is not getting the air because it was released by the BOV. You would end up with a very rich/wet fuel mix.
Generally , the CT26 spools at about 3300rpm's. Spooling earlier may indicate a pressure leak.Maybe the BOV.
Just a thought and worth checking out.
The Jedi Speeder at CarDomain
Old 10-13-2007, 09:57 AM   #5 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
that sounds pretty good... i was thinking just a general vacuum leak. wastegae maybe...
tHa kNiGHt FaLL is offline   Reply With Quote
Old 10-14-2007, 07:15 PM   #6 (permalink)
hey guys thanks...is there a way to test out your BOV if that is the problem? Is there any things i need to check for in the BOV to see if its bad?
Old 10-14-2007, 08:06 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
BOV should be closed at idle and when accelerating. Check all hose's and vacuum lines between the AFM and throttle body.Also check hose's to BOV, wastegate actuator and turbo.
