Engine starts but won't keep running? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2007, 02:38 PM   #1 (permalink)
View Diff Operator's Photo Gallery
2nd Generation Engine starts but won't keep running?
The car starts everytime and will run for about 15 seconds then stalls, somehow the fuel is getting cut off. The engine starts well with no smoke. Any ideas on whats causing this. This is a car I'm aquireing. Will be my second MR2 turbo, I'm just curious what would be causing this.
Diff Operator is offline   Reply With Quote
Old 10-04-2007, 12:41 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Are you sure it's the fuel being cut ? Sounds like a leak. Check all hoses after the AFM all the way to the throttle body inlet.
The Jedi Speeder at CarDomain
Old 10-10-2007, 06:26 PM   #3 (permalink)
View mr2kevin's Photo Gallery
yep probably got a air leak...do wat mr2bad said and also check vac lines for cracks or unplugged
mr2kevin is offline   Reply With Quote
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
Part Deux; 20R REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 21 09-06-2007 09:35 AM
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 07:30 PM
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
