Revving high - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2007, 10:28 PM   #1 (permalink)
View Pnoi's Photo Gallery
Revving high
Hey guys I have a little problem, just recently I changes one of my hoses because my car was overheating, but now after i fix my problem another one has came up my rev idle doesn't want to come down. When I start my car it revs up to 3000 rpm and after a little bit of warm up it goes down between 2000 and 2500 rpm and stay there even after i drive it. I already cleaned my throttle body and butterfly with throttle/ carburetor cleaner and its still high, and i don't thinks its the wires because I haven't touched any what can it be??? pls help? thank you.
Pnoi is offline   Reply With Quote
Old 10-15-2007, 11:57 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Sticky accelerator cable ? check at the throttlebody and foot pedal. If ok, try just adjusting your idle with the idle screw.
The Jedi Speeder at CarDomain
Old 10-16-2007, 03:52 PM   #3 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
what did you remove to get at the hose you replaced?
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 10-16-2007, 06:38 PM   #4 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
i've had more problems w/ that than can be imagined...
check for vacuum leaks...
is it just a high idle or do you have boosting issues too...?
tHa kNiGHt FaLL is offline   Reply With Quote
Old 10-16-2007, 10:43 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I noticed Sunday that my throttle cable at the throttle body is beginning to fray...
Old 10-17-2007, 03:04 PM   #6 (permalink)
Audi Technician
i've had that twice....
you kno what the problem was.... the main engine ground near the transmission was became loose and was grounding the engine out thru the throttle cable... the intense heat from the high amperage caused the cable to heat up and break apart over time.
Old 10-17-2007, 11:35 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Wow ! I never would have thought of that. I'm gonna make sure mine is grounded properly.
Thanks Drew. Once again, your expertise is appreciated...
High Beamin' hiace24 General Discussion 4 05-15-2006 01:12 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
High Beam Low beam swap dna59 Camry & Solara Lounge 3 09-08-2004 11:42 AM
