how do you fix if nitrogen oxide is high on smog check
so just and got my smog check done today for my 1992 toyota mr2 2.2L , and did not pass because it says that my nitrogen oxide is high being that at 15 mph the max is 807 and i got 1338 and then at 25 mph the max is 746 and i got 1728, wat type of problem does that suggest is going on with my car the smog tech said it is prob something to do with my air fule mix but how do i fix that please help
MAKING MY DREAM FLY FROM MY HEAD TO THE ROAD
unless your car runs very lean which i doubt... only two things control NOX and thats your EGR system and catalytic converter. take your smog results to mieneke and pay 50.00 for a failed smog diagnosis.
too many variable and its very hard to check your cat and very hard to explain how to test your egr
Anything that increases combustion temps will increase N0 levels. A lean engine will produce more N0. Issues to check:
Coolant system problems that raise coolant temps, leaky intake manifold gasket or vacuum hose leaks, defective 02 sensor, defective EGR system resulting in less exhaust gases being recycled into the engine intake; improper spark advance, initial timing incorrect; knock retard system not working correctly, carbon deposits on valves.
i had perfect readings and failed on NOX only... and my catalyst was the problem.
and toyomoho more than half your reasons are caught during a California Smog Inspection.
If there are engine codes they won't run they test, timing off more than 2 degrees they won't run the test. All monitors and readiness codes need to be set, and a vacuum leak will cause you run rich. which is hi CO levels... and it obvious that your car is overheating.
like i said... only two things fundamentally control NOX... and thats the EGR and the CAT.
apply vacuum to the negative back pressure transducer type EGR and the engine should stumble. release and it should return to idle.
I have a 1996 4Runner and I failed smog due to elevated NO as well. I took it to the dealer and I was told that I had a leaky head gasket and some water & coolant was leaking into cylinder #6 and that was cuasing a misfire. Apparently, my car was getting too hot and caused the head gasket to crack and potentially warped the heads (amzingly enough, I never overheated so I never would have known there was a problem).
I am looking to sell it and I will not pay a huge sum to fix it at this point. Now I am wondering what shortcuts I can take to smog the vehicle.
Radiator stop leak? (will it stop coolant from blowing into the cylinder)
Motor Honey?
I had the same problems as you have now... however, you want to pass like how i did?
What to do:
-buy a timing light (if you don't have one already)
-get a paperclip
-fill up on the highest octane fuel you can find at your local pump
-set the paperclip in TE1 and E1 terminals in your diagnosis port.
-loosen the distributor cap screws to retard the timing
-set the timing with the timing light to around 3' TDC
-GO TEST AND PASS
-Once passed, set the timing back to 10' TDC and you're smooth sailin'
1991 Toyota MR2 Turbo '96 Gen3, Intake, Exhaust, Stock boost for now [Summer Fun]
1992 Honda Civic VX [Winter Gas Saver 50+mpg ]
What to do:
-get a paperclip
-GO TEST AND PASS
Cant do that in California. You will fail for incorrect ignition timing..
1991 Toyota Celica GT-S 5SFE
1995 Nissan 240SX SE KA24DE
2000 Nissan Primera SR20DE GTSTWINCAM@yahoo.com
