Wheels & Tires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2007, 07:12 AM   #1 (permalink)
Rally_9RPM
redline_mr2's Avatar
View redline_mr2's Photo Gallery
Wheels & Tires
So, I have decided to buy some big and wider wheels & tires. I'm buying the Blitz Type 03 Wheels with Toyo Proxes T1R Tires. Now I have a little difficult picking the right wheel sizes for 91 mr2. Keep in mind I am going to roll my fenders. Here is the specs for the Wheels
SIZEBOLT PATTERNOFFSET HI DISCOFFSET LOW DISC 17x75x114.3
+28, +32, +35 17x85x114.3+35, +41+32, +38, +45 17x95x114.3+22, +41+32, +38, +45 17x105x114.32245
Now in the front I want to place a 215 wide tires at 17in wheel, so I believe the 17x7 with an offset of +32. Now for the rear I want to make it as wide as I can. I am trying to bolt 800hp to the ground. I was thinking 285 wide tire would work. Will that fit on the 17x9 or the 17x10? If it fits the 17x9 what offset would I need?
*Break For Honda*
"Trista" 422hp @ 15psi(Blown In Rebuild Stage)
redline_mr2 is offline   Reply With Quote
Old 10-22-2007, 09:37 AM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
If you are shooting for 800whp you must have deep pockets..... go get wheels custom made.
Old 10-23-2007, 03:05 PM   #3 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
a 285 would have to be a 10 inch wide...
a 17x7 w/ a 215.... w/ a positive 32 offset isn't much of a performance design...
those are typical "tuner" numbers...
your looking at like a 225 in the front and maybe a 275 in the rear.
wheels 17x8.5 or 17x9.0 w/ an offset of maybe +22 in the front and a +10 in the rear.
these are numbers i'm just throwing out there... but they are ballpark of where you limitation for stock fenders and wheel wells... i mean you can only roll them so much
tHa kNiGHt FaLL is offline   Reply With Quote
Old 10-26-2007, 03:44 AM   #4 (permalink)
Rally_9RPM
Well you can only increase the width on the front tires so much before you loose your ability to turn. I'm not sure how wide you can make the front. I no you can role the rear and add up to 11 inch tires. I think I'm going to have to move to a 265 the toyo t1r's only go to 265 on the 17's
*Break For Honda*
Old 10-31-2007, 02:45 AM   #5 (permalink)
View 1989PandaCamry's Photo Gallery
Sorry if thread jacking but quick question. Will some 5mm spacers help to fit a 17x8, 225/45/17 +45 offset wheel fit onto the front of the SW20?
1989PandaCamry is offline   Reply With Quote
Old 10-31-2007, 01:13 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
^That sounds too wide for the front. Though that offset is very tucked...
The Jedi Speeder at CarDomain
Old 10-31-2007, 01:21 PM   #7 (permalink)
Piddy's Avatar
Yea.... +45 is way too high of offset.... +40 would be closer to flush depending on your camber. You might have to go with a slimmer profile tire..... but you can definitely fit a 225 in the front on 17x8's.
Old 10-31-2007, 03:51 PM   #8 (permalink)
Audi Technician
you don't really want a high positive offset... you want closest to zero w/o rubbing... negative if possible. it will have the same effect as spacers plus you get a wider stance.
you get more of the "indy" effect when it comes to handling because your moving the pivot point farther from the wheel centerline increasing the turning radius
Old 11-01-2007, 10:13 PM   #9 (permalink)
Butters That's Me
View Boosted_SW22's Photo Gallery
if money aint an issue y the Toyo T1r tires.Ran them on my 2 and dont like them whatsoever.BUt it's your choice though....
Boosted_SW22 is offline   Reply With Quote
Old 11-01-2007, 10:48 PM   #10 (permalink)
Piddy's Avatar
Here ya go..... http://www.toyotanation.com/forum/t217306.html
Old 11-03-2007, 12:36 AM   #11 (permalink)
So you're saying that i can't run the tires on the rims with 5mm spacers and call it a day right?
Old 11-03-2007, 01:16 AM   #12 (permalink)
Piddy's Avatar
Spacers are retarded.... just buy wheels with the correct offsets to begin with.... even +40 would look silly on an MR2. +38 minimum in the rear.... plus they should be staggered.
Old 11-03-2007, 01:22 AM   #13 (permalink)
I can see where you are going with your idea of spacers being silly, but the thing is i was given some rims that are 17X8 and i was going to use them if they would fit with minimal fabrication. Seeing as that isn't going to happen i guess i'll just be using stock Rims.
Old 11-03-2007, 12:01 PM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
^Can you not use them on the rear ?
Old 11-03-2007, 12:29 PM   #15 (permalink)
Dont really like the look of mismatched rims.
Wheels for stock 17" tires Celerity 2nd Generation (2005+) 2 08-06-2007 10:39 PM
can I take off tires from stock wheels and put them on new wheels?(and reuse sensor?) germandebbie The Discount Tire Direct Tire, Wheel, Brake & Suspension 4 07-09-2007 10:07 AM
[b] New wheels and tires! [/b] TRD VVTi 5th & 6th Generation (2002-2006 & 2007-2011) 6 06-26-2007 07:56 AM
Selling TRD wheels + tires dELuX-4x4 2nd Generation (2005+) 0 03-02-2006 04:52 PM
rim manufacturers? fireman9170 2nd Generation (2005+) 6 02-19-2006 11:05 AM
