Car keeps shutting off? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2007, 04:19 PM   #1 (permalink)
View zizou10's Photo Gallery
Lately my '86 MR2 has been shutting off on its own. like when i'm at a stop light or parked while the car is on or trying to reverse it starts jerking and shaking and then shuts off. i start it back up again and then it drives fine. i changed the spark plugs, the oil, fuel filter but havent changed the spark plug wires yet. Could this be it??
zizou10 is offline   Reply With Quote
Old 11-10-2007, 12:06 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Possibly. When's the last time you checked your fuel filter?
The Jedi Speeder at CarDomain
Old 11-10-2007, 12:15 AM   #3 (permalink)
i just changed it like 2 weeks ago.
Old 11-10-2007, 12:17 AM   #4 (permalink)
TDG
FTW
TDG's Avatar
View TDG's Photo Gallery
Auto or manual
TDG is offline   Reply With Quote
Old 11-10-2007, 12:32 AM   #5 (permalink)
Originally Posted by TDG View Post
Auto or manual
its auto
Old 11-10-2007, 12:43 AM   #6 (permalink)
TDG
FTW
TDG's Avatar
Does it do it when the car is hot or cold or both
Old 11-10-2007, 12:50 AM   #7 (permalink)
it does it when i dont have the ac or heating turned on, and the temperature gauge of the car is normal like at halfway.
Old 11-10-2007, 12:55 AM   #8 (permalink)
TDG
FTW
TDG's Avatar
What does the car idle at when you're in gear if you know. Maybe your idle is set too low and once in gear it drops to far down for the motor to keep running while trying to push the car?
Old 11-10-2007, 01:05 AM   #9 (permalink)
man i gotta go. so what would your suggestion be if it is set too low? i really appreciate your help. thanks
Old 11-10-2007, 01:20 AM   #10 (permalink)
TDG
FTW
TDG's Avatar
If that is the case then just use a flat headed screwdriver and turn it up a little bit. If it doesn't do it when you've got the AC on then I would try that because AC will kick the engine idle up relay on and supply more power for the AC compressor.
If that doesn't work then start looking at your vacume lines, burp the coolant system, check the transmission fluid, make sure your air filter isn't stuffed up with dirt.
I'm out myself cause I'm falling asleep. Keep us posted on the issue.
Dylan
MKIV Scam registry bmw5002 Supra Forum 11 07-09-2010 11:59 PM
Thoughts on VIP Curtins for '07 Camry? darksparkz 5th & 6th Generation (2002-2006 & 2007-2011) 22 10-07-2007 02:35 PM
My experience w/ a 07 Camry SE I4 auto Linck 5th & 6th Generation (2002-2006 & 2007-2011) 49 08-14-2007 08:05 PM
FS: 1986 Corolla GTS VanishingVision Vehicles 4 06-24-2007 04:52 PM
drove a new Scion tC 5 sp, not really impressed Talisman 1st Generation (2005-2010) 45 08-29-2004 08:08 PM
