mr2 hks fcd/ fuel cut problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2007, 09:44 PM   #1 (permalink)
mccracing's Avatar
View mccracing's Photo Gallery
I have a 91 mr2 with gen III 3sgte. I put a boost controller on my vehicle to safely raise the boost after performing required upgrades to be able to push 16 psi. I installed the HKS FCD and my fuel cut is still hitting before 16 psi. I found that 13.1 psi of boost is the max that I can get before fuel cut happens. The unit is wired properly... any ideas?
mccracing is offline   Reply With Quote
Old 11-16-2007, 11:50 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
What number do you have your FCD set to? Doesn't sound like it's working at all..
The Jedi Speeder at CarDomain
Old 11-17-2007, 12:46 AM   #3 (permalink)
mccracing's Avatar
its an engine swap to the 3rd gen jdm motor. I have it set at channel 7. this is what hks recommended for the mr2
Old 11-17-2007, 11:32 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I have the same FCD set at 7 too. and it cuts fuel at 17psi. What boost controller are you using?
Old 11-17-2007, 12:12 PM   #5 (permalink)
mccracing's Avatar
the bcu unit that has a turbo timer and lo and hi boost settings. would the boost controller make a difference? my separate boost gauge reads the same psi as the controller
Old 11-17-2007, 12:26 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I'm using the Greddy ProfecII EBC. I have the boost limiter set to 16psi. When boost hits that level, the wastegate is opened to reduce boost. But it doesn't cut fuel. What do you have yours set to ?
Old 11-17-2007, 01:13 PM   #7 (permalink)
mccracing's Avatar
the warn is set at 16 psi the wastegate setting starts to open at 5 psi. fuel cut is hitting at 13 or a little earlier
Old 11-17-2007, 01:37 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Eithet the FCD is not wired correctly(which you said is) Or it just isn't working. Maybe defective.
Are you sure it's fuel cut?
Old 11-17-2007, 01:51 PM   #9 (permalink)
mccracing's Avatar
i triple checked the wiring. may be defective. it is fuel cut because check engine light comes on and pulls a code 34 and resets itself when car is turned off and back on again. should i raise the wastegate setting?
Old 11-18-2007, 12:18 AM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
If WG is opening at 5 psi, how are you getting to 13psi ?
Old 11-20-2007, 09:07 PM   #11 (permalink)
mccracing's Avatar
The boost controller instructions state that the 5 psi setting is where the wastegate staerts to open. i am able to change this setting. The HKS FCD was verified today that it is in working order. I changed the setting to number 9 (toyota supra) and I was able to gain .5 more psibefore fuel cut kicked in and the car idled/accelerated different. Tomorrow i am doing the pressure gauge/voltmeter test
Old 11-20-2007, 11:10 PM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Sounds like you're on the right track. I " think" the 9 setting is suppose to eliminate fuel cut altogether for the MR2. At least if I remember correctly. My instructions were in japanese, so I called HKS when i was installing my FCD. I thought thats what they told me. That was 3 years ago.
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Fuel Cut 91 turbo MR2 Forum 5 08-09-2004 08:24 PM
fuel cut on a 22r-tec emc General Discussion 2 05-13-2004 01:12 PM
MR2 overboosting problems need help BAD! IMPORTMyth01 MR2 Forum 4 01-18-2004 05:57 AM
fuel problems and other problems... trdG Camry & Solara Lounge 0 12-22-2002 10:36 PM
