Maybe someone out there could help me out. I have a 86 aw11 5 speed looking to swap in jdm c56 left over from corolla 4agze drift car project.
if it was the stock transmission on a 4agze, then it's not a C series transmission..... it is an E series transmission....
I know about drilling the case and swapping the shift linkage. I was wondering if the bell housing will bolt up to older 16v engine
yes it will need to be and yes it will.... the only transmission from an A series car that won't bolt up to any 4age is the alltrac's transmission
I know the clutch will need to be changed but what about axles?
it depends on if it's an E series or a C series.... all FWD C series transmission (from A series cars) use the same axles. You can keep the clutch and flywheel combo you have if it's a C series. If it's an E series, then you will need different clutch, flywheel, pp, and axles. The axles will be difficult to find for an aw11.
Also does anyone have or know where to get input shafts for c56 that match up stock axles.
should be the same if it's a C series
thanks Also does anyone know if an automatic 4agze e.c.u work in a stick application?
yes, it will..... you will have a constant CEL on however
