c56 vs c60 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2007, 06:12 PM   #1 (permalink)
View 86black2's Photo Gallery
Gen1 c56 vs c60
I have a trans from a jdm 4agze engine that was for a corolla? does anyone know what car that might have come from? Also was told that trans was a 6 speed with a l.s.d maybe a c60 how could I tell? Will it fit into a mk1 mr2? And whats the difference between s/c and n/a mr2 axles if any? p.s I know about a c56 swap is a c60 swap different? P.S. are'nt supercharged cars aw16 chassis code not aw11
86black2 is offline   Reply With Quote
Old 11-19-2007, 08:45 PM   #2 (permalink)
Gameroom cash: $134355
you could have asked in the other question.....
all C series transmissions were NEVER on any 4agze. The c56 came on the silvertops and blacktops (5 speed) and the c60 was the optional 6 speed for the blacktop.
the 4agze in the aw11's came with an e51, the early ae92 had a fwd e51, and the later ae92's and ae101 4agze's had e58's. All fwd e series transmissions utilized a passenger axle that bolted to the block and didn't have a c-clip to retain the axle.
the only LSD factory equipped corolla's/mr2's (A series) were non-us s/c aw11's (was an option, not standard) and on some FWD vehicles. The LSD transmissions use even different axle splines (inner) than the e51's.... those axles are even MORE difficult to find.
Old 11-20-2007, 12:08 PM   #3 (permalink)
Gen1 Which one?
Well thanks alot, i'll just have to pull the axles from my 89 and see if they fit? also why is the c56 a popular swap why not justbstick with the stock unit?
Old 11-20-2007, 05:21 PM   #4 (permalink)
they're newer... have a slightly different gear ratio, and have less possibility of losing syncro's
but it isn't all that common of a swap.
the E series are used in s/c swaps because they're MUCH stronger than the stock c series
Old 11-22-2007, 01:50 PM   #5 (permalink)
Gen1
So am i better off just keeping the stock unit and rebuild it with new main bearings and synchros when i install a diff? also can i take gears from other c series to get ratios i want? does a automatic s/c car nave same axles as n/a? thanks
aw11 c56 swap 86black2 MR2 Forum 6 11-22-2007 01:17 AM
C52 vs C56 Conquestdriver 6th Generation (1988-1992) 6 11-05-2007 03:53 AM
C56 vs C160 Mounts/Length richard_rsp Archived Corolla threads 12 05-28-2006 07:46 PM
C56 final drive 94_Rolla_Guy Archived Corolla threads 6 11-16-2005 01:46 PM
C56 Trans vs C52 EProd23 Archived Corolla threads 6 01-25-2005 03:41 PM
