NewB Q: how much would it cost to do a j-spec engine swap on 93 mr2t? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2003, 12:29 AM   #1 (permalink)
View JT_mr2's Photo Gallery
Hey, just wondering how much is would cost to buy and swap a j-spec mr2t engine into it. Im thinking of getting a mr2t.... thanks a lot.
JT_mr2 is offline   Reply With Quote
Old 09-19-2003, 04:29 PM   #2 (permalink)
View lokn2bimr2's Photo Gallery
what is a J-spec MR2 turbo engine? I've seen it referred to in other places - is that something different than the stock engine?
lokn2bimr2 is offline   Reply With Quote
Old 09-23-2003, 06:33 PM   #3 (permalink)
View hugmybag's Photo Gallery
J-spec= Japanese spec= JDM= Japanese domestic market
I wouldnt do it, had a friend who did it and it gave him nothing but trouble.
'91 mr2 tuy-bo
hugmybag is offline   Reply With Quote
Old 09-24-2003, 02:15 PM   #4 (permalink)
View Neal18T's Photo Gallery
hey im new to the board 2 and im interested in this question also...
ive been trying to find the exact specs for the Jspec motor... does anyone know them? I found a couple sites but they were all in Japanese :p
anyways yeah id be interested in this also because then i can pick up a NA motor'd MR2 for cheaper and get a lower KM motor to swap in...
most of the turbo engines up for resale have very high km's 150K + ussually =(
13 second VW 1.8T
Neal18T is offline   Reply With Quote
Old 12-15-2003, 11:41 AM   #5 (permalink)
Bone Stock :(
View TRD2000GT's Photo Gallery
Where to find an 98 Jspec engine?
'91 T
My Site
TRD2000GT is offline   Reply With Quote
Old 12-15-2003, 04:40 PM   #6 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
the most desireable motor would be the 3rd gen motor.....i copied this from a post on the main board.....
FYI: Gen III Differences
- MAP sensor instead of AFM
- Bosch D-Jetronic (Gen III) vs. L-Jetronic (relatively primitive) engine management
- CT20b turbo replaces CT26
- Boost raised from 10psi to 13psi
- Fuel cut raised from 12 psi to 18 psi
- Different ECU
- 4 wire O2 sensor
- Shim under bucket valve shims
- slightly more aggressive cams
- Revised internals (pistons, con-rods etc.)
- Revised cylinder head cooling passages/water jackets
- Revised intake manifold (8 'independent long ports' reduced to 4)
- intake manifold inlet air temperature sensor added. i.e. after turbo and intercooler.
- Revised gearbox with close ratio gearing
- lower compression ratio
- stainless steel head gasket
- factory 540cc injectors replace 430cc injectors
- revised fuel rail with bigger bore and relocated pressure regulator
- TVIS eliminated
- EGR eliminated
- LSD in 80% of them
- throttle body increased from 55mm to 60mm
- inlet valve lift increased from 8.2 to 8.7
- Less restrictive exhaust elbow
- Aluminum oil pan
- more rigid alloy sump and additional oil baffles
- Factory Catch can
- Better Oil Cooler and relocated oil filter (bottom)
- 4 Channel ABS coupled with Traction Control available
- No. 1 compression ring described as 'stainless steel' instead of just 'steel'. Oil ring is described as 'stainless steel' instead of 'a combination of steel and stainless steel'.
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 12-15-2003, 10:21 PM   #7 (permalink)
View mr2freak's Photo Gallery
gen 3 is between 240-250 hp, with 200 lbs of torque
it would come to about 5 gran
Women... can't live with 'em, can't shoot 'em - 87camry5speed
Seriously... PETA is a militant group. They suck in genuinely concerned people, and spit out hitler faeries - Toysrme
mr2freak is offline   Reply With Quote
Old 12-23-2003, 08:49 PM   #8 (permalink)
View Nateness's Photo Gallery
I've seen that Neishlin Motors sold a few GenIII halfcuts for around the low $3k range... i'd think that $5k would be for installed, right? Though I heard some talk in the IMOC that the block casting on the GenIII was "cheaper" than the casting on the GenII block.. but that was off a 3S-GTE on a Celica GTS w/ GenIII
'91 MR2 N/A
Nateness is offline   Reply With Quote
Old 12-25-2003, 03:21 PM   #9 (permalink)
Daz
View Daz's Photo Gallery
First Gen: 88-89 : 180hp, celica all-track
Second Gen : 91-95 200hp 200 torque in celica all track + mr2 turbo
Third Gen: 96-99 : 245 hp 240 torque in mr2 and all-track outside of america, where that engine stoped to be imported
The j-spec engine Second Gen got 225 Hp and 220 torque
Daz is offline   Reply With Quote
