5sfe cams in a 3sgte - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2007, 02:04 PM   #1 (permalink)
View clem's Photo Gallery
have anyone tried this as yet and if not what do you think will happen will i gain more horse power or would i lose horse power?
clem is offline   Reply With Quote
Old 11-22-2007, 02:34 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Not possible.... the 5sfe cams are retarded. They have a gear in the middle that connect the two cams together. If you have a 2nd gen 3sgte you can throw in some 3rd gen cams for some gains. Otherwise there are several options for aftermarket cams.
Old 11-22-2007, 04:54 PM   #3 (permalink)
i just was curious there is some other question i have to ask does the na mr2 ac compressor bolt directly onto the turbo mr2 motor
Old 12-03-2007, 01:48 PM   #4 (permalink)
6G Celi Specialist
Supersprynt's Avatar
View Supersprynt's Photo Gallery
Yes
Supersprynt is offline   Reply With Quote
Old 12-11-2007, 01:27 AM   #5 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
also, regarding cams, if you get cam gears and retard the exhaust cam a few degrees, you'll pick up some nice top end gains, without hurting spool or low end torque. that is effectively what toyota did with the genIII cams.
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 12-11-2007, 10:07 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
-Mike
Does that work with stock gen II 3sgte ex. cams?
The Jedi Speeder at CarDomain
Old 12-11-2007, 11:31 AM   #7 (permalink)
3SGTE & 1GRFE
yes, using stock genII cams, retard the exhaust cam about 6 degrees, IIRC, and it helps a bit with the top end, something like 10whp.
-Mike
Old 12-11-2007, 01:01 PM   #8 (permalink)
Piddy's Avatar
You will need adjustable cam gears.
5SFE vs. 3SGTE 2nd GEN 92MKll MR2 Forum 16 11-30-2006 11:37 AM
3sgte vs 5sfe MameXP Celica Forum 7 04-06-2006 02:08 PM
91 5sfe to 94+ 3sgte? amlikon MR2 Forum 3 08-15-2005 12:15 AM
5SFE 3SGTE Deck Height Bugermass MR2 Forum 2 03-08-2004 05:45 AM
Found Cams for the 3sfe (also 5sfe) Talisman 3rd & 4th Generation (1992–1996 & 1997–2001) 1 02-27-2004 10:51 PM
