MK1 poor throttle response(low RPM) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2007, 06:12 PM   #1 (permalink)
View 86black2's Photo Gallery
I have an 86 mr2 and when i got it the idle air screw was rusted in place so i switched the throttle body out for one from an 88 mr2. the 86 is stick and the 88 auto when i switched i had to change T.P.S sensor because plug was different so was the I.A.C valve but i did'nt change that now when i slightly press on the gas at idle it starts to lope and is hard to keep within a specific RPM range (below 3k) is it the I.A.C? Would it be different for an automatic? Could I have hooked something up wrong? OR is it something else? P.S. When cold the car idles around 2k and drops to like 8-900 after it warms up. The car also threw an o2 sensor code on C.E.L could this be it? THANKS
86black2 is offline   Reply With Quote
rpm window switch misfire omegarex 3rd & 4th Generation (1992–1996 & 1997–2001) 2 01-14-2007 10:38 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
What the XRS needs. kini Archived Corolla threads 18 02-09-2005 10:37 AM
deciding on a car toyota vs mazda koss78a Archived Corolla threads 104 10-20-2004 12:15 PM
air fuel ratio questions... HPR Archived Corolla threads 12 12-02-2003 07:10 AM
