Battery Light Stays on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2007, 12:31 AM   #1 (permalink)
View jameson75's Photo Gallery
Hello everyone:
I have a 1993 MR2 Turbo. The battery light stays on after the car starts. Since the car isn't driven often, I decided to change the battery. The alternator has also been changed before, maybe about 4 years ago. After changing the battery the light still stays on. I have this battery charger/tester machine. When I connect it to the battery its reading at about 13-14. The engine is on and I can see the volts moving up. when I put a load on it (turn the lights on, radio) it drops down to 12.9. when i turn the load off it moves back up to mid to high 13's volts. so i'm assuming the battery is being charged by the alternator?
Any ideas of what it can be??? BTW, my reverse lights don't work either, even after I changed the bulbs. do you guys think that might have something to do with the battery light?
thanks in advance.
jameson75 is offline   Reply With Quote
Old 12-05-2007, 08:37 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $136123
View Hajoca's Photo Gallery
Alternator has a regulator (diode pack) that seems to be malfunctioning.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 12-05-2007, 11:10 AM   #3 (permalink)
Thanks for the prompt reply. I replaced the alternator a few years ago and it wasnt a pleasant thing. Is the regulator a part on the alternator that i can replace or do i have to replace the entire alternator. the alternator is such a tough part to get to.
thanks.
Old 12-05-2007, 01:05 PM   #4 (permalink)
Darkside Cut Me!!!
There is a diy for alternator rebuild here on the forum by TERCELGTS ??
The alternator has to come out no matter what, you should be able to check by grounding the field windings, look at the camry service manual in the camry links section (same alternator).
Then if the voltage goes back up then your regulator is bad.
2004 RX330 Sport
2003 Cam I4 XLE
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 07:40 AM
Battery light problem? illuzionx 3rd & 4th Generation (1992–1996 & 1997–2001) 11 07-21-2008 03:33 PM
Brake and battery dash light stays lit for a few min awdark Archived Corolla threads 7 02-11-2006 04:38 AM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
97 Avalon Seat Belt Light Stays On slappy_545 1st Generation (1995-1999) 0 03-12-2005 07:51 PM
