My AW11's gears keep grinding!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2007, 02:57 AM   #1 (permalink)
86MR2
GabMR2's Avatar
View GabMR2's Photo Gallery
Canada My AW11's gears keep grinding!!!
Hey guys, im new to this site, and i need a little help.
I've got an MK1 MR2 and my gears keep grinding, my reverse is horrible, its so bad im embarrased to pull out of a parking space when people are around. I checked the clutch fluid and it was nearly empty, so i refilled it. It seemed to work for a day or two, but then it started grinding again, I checked the fluid container and it was full. Im out of ideas. Should I shange the tranny fluid for now? Would it be best to buy a new transmission? Or should I check the clutch and cables? This is my cars first time being winter driven and surprisingly it doesn't handle as bad as i thought. I know they're not meant for winter but could the cold be the reason for the grinding eventhough i keep it in a garage?
Thanks to anyone who replies.
GabMR2 is offline   Reply With Quote
Old 12-07-2007, 10:05 AM   #2 (permalink)
masco's Avatar
View masco's Photo Gallery
Change the transmission fluid, I have a feeling like it might help a lot.
Most manual transmissions are a bit harder to shift in the winter...until they warm up.
1990 Toyota Celica Turbo4wd
masco is offline   Reply With Quote
Old 12-07-2007, 08:31 PM   #3 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
yea cause reverse gear doesn't have syncros.... and if its doing it in all gears... if not fluid.... your looking input shaft issues...
tHa kNiGHt FaLL is offline   Reply With Quote
Old 12-09-2007, 07:21 PM   #4 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
what the hell is clutch fluid? Ive never put any fluid into my clutch......they are supposed to be friction devices....and on top of that how would you?
Also my car is a custom 3SGTE swap in a MK1 im grinding a gear in 5th..... mine is grinding however because my cable is too long and wont engage the gear fully.....maybe there is something wrong with your cables, take a close look at them.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 12-09-2007, 10:23 PM   #5 (permalink)
86MR2
GabMR2's Avatar
Canada
My clutch container is a small clear tube that sits next to the brake booster under the front hood. I didn't know what it was but then i checked the manual and its for the clutch and it uses DOT3 brake fluid.
Old 12-09-2007, 11:03 PM   #6 (permalink)
Midship Captain
ModifierMR's Avatar
^lol im sorry, my brain went dead....lol havent slept much latley...I know exactly what you are talking about and I feel really really stupid.
I should know this because Installed a whole new clutch line in my MR2 with a new master and slave cylinder.
すべての日本への私のお悔やみ。
Old 12-10-2007, 11:13 AM   #7 (permalink)
View vishal25pm's Photo Gallery
try bleeding your clutch. i had this problem when i first put my 20v in and a rebuilt c56 transmission. rebleed the clutch and give it a try.
vishal25pm is offline   Reply With Quote
Old 12-10-2007, 10:20 PM   #8 (permalink)
View WT Morgan's Photo Gallery
Check your shifter linkage connections under the shifter boot. The nuts can get loose, the throw gets sloppy and gears grind.
You can chase all the complex possibilities and get real frustrated and then find out it was just this simple adjustment. I've seen it happen with MR2s.
WT Morgan is offline   Reply With Quote
BOMZ Cam gears? Ever heard of 'em? Your Uncle Moe General Discussion 7 09-13-2007 08:17 PM
4.88's gears are out there for our trucks. Adventure North 2nd Generation (2005+) 1 09-12-2006 04:37 PM
grinding gears? rice Archived Corolla threads 5 03-10-2006 01:05 AM
5efe adjustable cam gears....group buy in the making kene Yaris, Vitz and Echo Forum 0 06-24-2004 01:47 AM
Metal grinding noises..... camrydriver7609 Hardcore Tech and Competition 2 07-04-2003 07:17 PM
