Fuel injectors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2007, 01:14 PM   #1 (permalink)
mr2oogleX
View moogleX's Photo Gallery
Fuel injectors
been reading up on the options and what to choose. acording to the power primer the stock 440's need to be replaced at or around the 275 mark, and the 540's in the gen III or supra option upgrades only support up to 330. Wolfkatz recomends using larger than needed injectors as it MAY increase injector life.
poking around people recomend the blitz 850's with a wolfkatz side feed, or 680's on a wolfkatz top feed. I dont plan on going up to 4-500hp, just like 330-340 or so. should i stick with the supra injectors and just pick up a new side feed rail? or go with the top feed and the 680's incase my setup runs higher than 330hp?
also a walbro pump, hydra ecu, and a new fuel pressure regulator will be on the list of things to get. power is expensive looking at $2400 atm
reason for the asking, is I was looking at the berk gt30 set up, or possibly the gt28rs kit from koracing.
Originally Posted by Quandry
...Turbo's have vaccum too, it's just not the fun part of the gauge
moogleX is offline   Reply With Quote
Old 12-09-2007, 01:55 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Sard makes an 800cc side feed injector that you may want to consider. I believe Wolfkatz carries them. If you email Garrett with your power goals and turbo option he will be able to recommend a good fuel setup. If you are shooting for mid-3's I would recommend getting something better than the 550's.
If you are planning on doing this you will be spending much more than $2,400.
Old 12-09-2007, 07:33 PM   #3 (permalink)
mr2oogleX
was looking at 325 for the wolfkatz top feed fuel rail, 75 per 680cc injector, 1500 for the hydra ecu, 110 for the walbro fuel pump, and 145 for the fuel pressure regulator. always open to suggestions and better deals
im sure there are somemore hiddon costs or something i forgot, but thats the plan so far. got about six months before i can afford it all though so plenty of time to plan
Fuel Injectors Leaking! jmailbox8 89-95 Toyota Pickup/Hilux 3 09-25-2007 07:31 AM
FS: fuel injectors for 1mz-fe adam2562 Car Parts for Sale 0 02-25-2007 07:16 PM
fuel injectors on a 3sge (turbocharged) not 3sgte mechanix0889 Celica Forum 0 02-10-2006 07:46 AM
Cleaning fuel injectors hdsalinas Archived Corolla threads 14 08-30-2005 05:11 AM
97 Corolla Fuel Injectors hazer00 Archived Corolla threads 0 05-19-2005 09:08 PM
