92 mr2 n/a auto to manuel need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2007, 03:40 PM   #1 (permalink)
View lethallykreated's Photo Gallery
2nd Generation 92 mr2 n/a auto to manuel need help
i got a 92 mr2 N/A auto and i just bought another 92 MR2 N/A that needs engine work so i wanna take the 5 spd tranny out and replace the auto tranny with the 5spd do i have everything i need since i have the whole car or do i need to customize stuff and what do i need 2 do???
lethallykreated is offline   Reply With Quote
Old 12-29-2007, 12:19 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
You should have everything you need. Clutch master, slave, hydrolic lines, clutch pedal, spring, clutch saftey start switch, stick shift, shifter bushings, shifter cables, trans, flywheel,and clutch. You will need to replace the flyweel bolts. The old ones should not be reused. Don't forget to use a threadlocker on the flywheel bolts..I think the hardest part will be running the shifter cables.
You might consider just swapping the engines instead.
The Jedi Speeder at CarDomain
Old 12-29-2007, 09:53 AM   #3 (permalink)
thanks for the info thats what i was worried about with them lines lol i would do the swap but the engine is done in the other mr2 im pretty much using it for parts
Scrapyard in the GTA TdotTercel General Discussion 16 11-23-2011 03:18 PM
MR2 n/a vs. MR2 turbo GoneIn10 MR2 Forum 9 05-13-2007 09:40 PM
purchasing an mr2 N/A vs turbo pastcivicowner MR2 Forum 16 07-07-2005 01:06 AM
Hey I got a 92 MR2 N/A, just a few questions 92MR2 MR2 Forum 6 09-23-2003 12:21 PM
Thinking about buying 92 mr2 aznricer MR2 Forum 2 06-25-2003 11:33 PM
