timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2008, 06:45 PM   #1 (permalink)
View llibb's Photo Gallery
timing belt
I've rebuilt the head on my MR2 and have an issue with the timing belt. It "walks" on the pulleys (I don't know which one) and rubs against the block, shredding the belt. The belt tensioner is with-in specs and I can't see an obvious mis-alignment. Any ideas and suggestion to cure this problem greatly appreciated.
llibb is offline   Reply With Quote
Old 01-09-2008, 11:08 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I just went thru this a couple of months ago. Did the same exact thing you're describing.
Make sure the #1 idler pulley still has a washer behind it. It's tight in there and when you remove that pulley,you prolly wouldn't have even noticed the washer behind it and it may have fallen off and not been replaced. It's crucial in the alignment of the pulley's. Without it, the belt "walks" inward and gets chewed up in no time.
The Jedi Speeder at CarDomain
Old 01-10-2008, 12:17 AM   #3 (permalink)
Thanks. I'll have a look to see if I missed that washer. Will let you know how it turns out.
timing chain or timing belt? hannahliang RAV4 Forum 1 12-20-2006 12:55 PM
Timing belt roplacement on 7A-FE engine smcinrox Archived Corolla threads 8 11-10-2006 10:27 AM
LS400 Timing belt ryanbls400 General Lexus Discussion 0 02-04-2006 07:41 PM
What seals can I replace with timing belt? Kitto Camry & Solara Lounge 2 01-07-2006 03:38 PM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
