Engine leaking coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2008, 09:05 PM   #1 (permalink)
View 95lambo's Photo Gallery
Hi there everyone,
I have a '91 mr2 turbo and am leaking coolant from somewhere under the turbo area. I can't see where its coming from because the firewall is in the way. Should I cut out the firewall...just kidding... I have tried looking under the car and cannot locate the leak from there either. I just know it leaks alot and I'm thinking freezplug. Has anyone else had this problem.
Thanks
Benj
95lambo is offline   Reply With Quote
Old 01-12-2008, 09:19 PM   #2 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
sounds like the usual Hose From Hell (HFH). Do a search on MR2OC and i think there is a how to on the replacement of it. But as you can tell by the name its not fun to replace
TheEngineer is offline   Reply With Quote
Old 01-12-2008, 10:32 PM   #3 (permalink)
Thanks for the quick reply, I tried looking up the problem on the site you mention and could not find anything. But there is a coolant hose between the firewall and the block for sure?
Old 01-13-2008, 12:19 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Actually, there are 2 hoses underneath the turbo and between the block and passenger compartment firewall. The hose from hell(HFH) as Engineer pointed out, and another small one that goes to the oil cooler at the base of where the oil filter screws in. If thats the hose(s) that are leaking, you will have to remove the turbo and downpipe to get to it. The actual hoses are only a few inches long. Best to replace both while you're down there.
There is also 2 bypass lines that are made of metal that come from the water pump area and thermostat housing that lead to rubber hoses that cool the turbo. Their connection to the thermostat housing is sealed by an O ring. They don't usually leak there though. Thermostat housing could also be a possiblity for a leak. But I think I would agree with The Engineer and start my search at the hose from hell.
The Jedi Speeder at CarDomain
Old 01-13-2008, 01:08 AM   #5 (permalink)
Thanks again for the quick reply I will put my fire suit on and check it out, ha, ha. Nice pic of the mr2 by the way.
Thanks guys
Old 01-14-2008, 05:44 AM   #6 (permalink)
new problem
OK here goes, I found this site called mrtwo.net they give great instruction on changing the HFH. BTW the site gave the exact details of the symptoms I experienced, so you guys are right. Before I posted my problem I started pulling the turbo heat shield attempting to remove the turbo in order to locate my problem. While doing so one of the rusty bolts stripped, and the one near the firewall feels like is going to do the same. I do need to replace the clutch soon so I thought of just pulling the motor and fixing everything.
Yes or No? Also if yes can I remove the motor from the top or does it need to come out from below?
Thanks
Benj
Old 01-14-2008, 07:22 AM   #7 (permalink)
well it all depends on the equipment you have to remove the motor. If you have an engine lift you pull it from the top. But most people dont have that equipment so they just put the car on 4 jack stands and have the rear high enough to drop it though the bottom
Old 01-14-2008, 07:29 AM   #8 (permalink)
Thanks
Boy, you guys are quick, I do have an engine hoist so, sounde like the top is for me.
Thanks alot
Benj
Old 01-14-2008, 07:52 AM   #9 (permalink)
Im more bored than quick...haha. When it gets slow at work, the forums become my work
Old 01-14-2008, 11:52 AM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Pulling it would be easier to work on everything and I think top is easiest too. Especially if you have a hoist.Then you can avoid removing the rear cross member. I found a couple of bolts that stripped out too. Use antisieze where bolts get really hot and tend to rust when you reassemble.
Oh, Engineer- Love the Sig!
Old 01-14-2008, 02:38 PM   #11 (permalink)
thanks
Old 01-22-2008, 05:11 AM   #12 (permalink)
HFH Replacement
Well, I descided to change the HFH this last saturday, took me around 7 hours, WOW for just a hose that costs less than 4$ from the dealer. It was a bear I must say, I changed it without pulling the turbo. If you take out the upper and lower parts of the oil cooler and then lay over a comforter accross the engine. I put my feet carfully toward the drivers side tail lights, you can kinda see what your doing, sometimes I had to stand on the passanger side to reach as well. Anyhow is works fine until I'm ready to do the clutch job.
Thanks to everyone
Old 01-23-2008, 12:15 PM   #13 (permalink)
yup theres a reason its called the Hose from Hell
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
