Oh no... timing belt riddle!
Seriously, my son just bought a nice used 87 mr2 with 1600cc motor (I think 1594 actually. The guy he bought it from said it had been rebuilt 14,000 miles ago.
My son drove it about 100 miles and the engine suddenly stalled and won't restart.
Fuel is fine, spark is fine, so I took it to my mechanic and he said compression is low (50psi) on all 4 cylinders. Strange... I suspected the guy lied to us until I took the pan off and saw the bottom of the cylinder bores looked nice.
So next I wanted to look at the valves... but in lining up the camshaft timing marks to remove the timing belt, I was spinning the crankshaft and noticed that it took about 30 degrees of motion before the cam sprockets started moving.... really strange!
Belt looks fine, no teeth missing and the belt tension was OK. The weird part is that the cam belt pulley sprocket down on the crank has about 30 degrees of "play" in it. This is where the delay in the camshafts is coming from.
So the question is, is this normal on these motors or should it be ridgidly mounted as all other motors I've worked on are. If it isn't normal I believe that the valves are not in time with the compression stroke and bleeding off compression by not being fully closed at the appropriate time.
Don't worry, I checked the top of the pistons and there are no marks from a collision with the valves. Valve stems are also straight.
Thanks, Chase
