Timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2008, 01:49 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Timing
Have '91 MR2 turbo.(3sgte)
When I reassembed the engine, I looked up timing specs-10 degrees BTDC. Got out the timing light and set it. I was looking at the BGB the other day and noticed it says to short
TE1 and E1 in diag. box when setting the timing. I didn't do that. Is that neccessary? What effect does that have? I intend on going back and retimng the engine using that method, but I am curious as to the reason for this and what that does?
The Jedi Speeder at CarDomain
Old 01-16-2008, 02:11 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Shorting TE1 and E1 will display your engine codes if you have any. I'm not sure what effect this would have on timing.
Old 01-16-2008, 06:33 PM   #3 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
it sets it into base timing... which is timing at its lowest idle rpm w/o stalling the motor.
its supposed to disable any advances... anything that can effect timing... so you can get the base reading...
tHa kNiGHt FaLL is offline   Reply With Quote
Old 01-16-2008, 10:56 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Yes, i've done that to check a CEL-#41: Throttle Postion Sensor. Which I checked out and ended up replacing.
OK,Thanks Drew- .
When I installed the new timing belt, I guess it had skipped a notch and the timing was off. It would barely idle. After re-aligning the belt correcctly , and setting the timing(10 degrees BTDC)is when the CEL came on with the code 41. Like I stated previously, I replaced the TPS, but still get the same code. I was wondering if not Shorting TE1 and E1 when setting the timing had anything to do with it.
Any ideas?
Old 01-17-2008, 11:43 AM   #5 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
no, that had nothing to do with it. jumpering e1 and te1 disables the ignition advance, it IS necessary for setting base timing correctly.
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 01-17-2008, 12:30 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
OK, Thanks Mike.. Any thoughts of what might be going on with the TPS ?
Old 01-17-2008, 03:31 PM   #7 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
I have never timed my 3SGTE.....
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 01-17-2008, 11:14 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
^ actually, I felt I needed to since I tore it down to the block, honed all the cylinders, ringed all the pistons and replaced one piston. Rod bearings too. But when I reassembled it and checked the timing(expecting it to be off), it was dead on.
I'm going to retime it using the TE1 And E1 thing and see if it makes any difference.
Old 01-19-2008, 08:18 PM   #9 (permalink)
Audi Technician
whats code 41 actually mean...?
Old 01-20-2008, 12:18 AM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Here ya go....
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 166 04-09-2012 10:44 PM
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
04 Celica GTS Timing Turbo2tom Celica Forum 2 12-18-2007 03:03 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
Part 2: Advancing cam timing allblackalltrac Hardcore Tech and Competition 0 04-16-2004 05:27 PM
