T top Leak when raining:( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2008, 01:05 PM   #1 (permalink)
View Przemik2008's Photo Gallery
The T top from pasanger side is leaking by the window... When it's raining the water coming on pasanger right shoulder ahhh please help...
Przemik2008 is offline   Reply With Quote
Old 01-21-2008, 01:57 PM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Kbox sells new T-Top weather seals for $179 (For AW11): http://www.kbox.ca/catalog/product_i...products_id=55
if you want to go a cheap route, sometimes if you take a bead of sillicone around the inside of the weatherstripping where the glass meets the rubber, and let it dry, when you put the T-Top back in, it should re-seal.
Here is a good Tip site for info on how to seal a T-Top leak: http://mr2wiki.com/MKI/T-Tops
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 01-21-2008, 09:25 PM   #3 (permalink)
View fibber1200's Photo Gallery
how about a 91 mr2? is there anyone know how to fix it i had saw a tools on ebay which is saying it can fix it,it only 20 dollars and it was a four pieces of rubber things. just wanna know did anuone try it before thanks
fibber1200 is offline   Reply With Quote
Old 01-21-2008, 10:00 PM   #4 (permalink)
Midship Captain
ModifierMR's Avatar
Im not sure, I own a 89 MR2. The same steps to fixing AW11 T-Tops should work with the SW20.
ask on MR2oc.com they should be able to answer better.
すべての日本への私のお悔やみ。
Old 01-21-2008, 10:15 PM   #5 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
i've had luck with using a silicone lubricant called shin-etsu...its actually a honda product but since i've applied it to my t-roof seals...i haven't had any leaking issues.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 01-22-2008, 12:11 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I've tried this product. They replace the stock grommets and make for a tighter seal.If it's a small leak, it'll work. Mine leak was small and it worked for a few months. But after 1 of our 100+ degrees summers, the rubber weather seals deteriortated more and it began to leak again.
After that, I used a sealant, which I did only as a temporary fix, but it has held up for over a year now. There is no doubt that I will have to replace the weather stripping-eventually.
The Jedi Speeder at CarDomain
97 2.2l oil leak help bronzemaxell 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-15-2007 09:10 AM
can V-6 tensioner leak oil? Robert K 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-03-2007 05:50 PM
Oil Leak when Accelerating??? renmike 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-08-2006 08:41 PM
black top into a ae92 gasman Archived Corolla threads 5 03-07-2006 02:23 PM
7mgte 87 major leak mseii Supra Forum 2 10-13-2004 06:43 PM
