Side air intake removal ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2008, 02:34 PM   #1 (permalink)
Terry MR2
View terrymr2's Photo Gallery
Hello everyone. I am thinking of buying a pair of veilside side skirts. They are the type that change the twin air intake vents on the side of the car into single vents. The question is, do I need to remove the thin black plastic strip above the vent to remove it, or will the vent 'pull off' without having to remove the strip?
Thanks for your time. Terry
terrymr2 is offline   Reply With Quote
Old 01-22-2008, 02:41 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
You will have to remove it. There is a small screw on the end. A 10mm nut in the wheel well. And another 10mm nut that you access through the inside of the car. This requires taking your rear side interior panels off.... there is a small circle cut out in the metal to access this nut. Be careful not to drop it. This will require deep sockets as well.
Old 01-23-2008, 03:48 AM   #3 (permalink)
Terry MR2
Side skirts.
Thanks Piddy for the advice. Can I also just ask, another quick question?!
I currently own a J reg Glimited import. Can I ask what the difference was between the 'normal' MR2 and the Glimited model?
Thanks again for your time.
Terry.
Old 01-23-2008, 12:00 PM   #4 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
never heard of it. Glimited?
But like piddy said, the strip is pretty easy to remove
TheEngineer is offline   Reply With Quote
Old 01-23-2008, 01:28 PM   #5 (permalink)
Piddy's Avatar
G-Limited is the Non-US version of the NA 3SGE powered MR2's. I'm not sure what the difference is between the G-Limited and a standard NA.
Old 01-23-2008, 01:36 PM   #6 (permalink)
Terry MR2
Thanks guys for the feedback !
HELP! Performance upgrade for a v6... afnan_jamil 3rd & 4th Generation (1992–1996 & 1997–2001) 61 10-08-2006 05:25 PM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
Ractive Ram Air system. Camry_rider Hardcore Tech and Competition 51 07-23-2004 11:03 AM
The Best Air Intake System (Cold Air, Ram, or Custom) aleks77 Camry & Solara Lounge 6 07-21-2004 11:50 PM
