bov sounds weird - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2008, 01:03 AM   #1 (permalink)
View jdm_mr2's Photo Gallery
bov sounds weird
i installed an after market blow off valve, its the "turbo X RFL model....
its really hard to explain but when i shift gears the bov sounds like its having a hard time blowing out if that makes any sense, i don't get the clean sound im looking for...does anyone know whats wrong??
jdm_mr2 is offline   Reply With Quote
Old 01-23-2008, 05:20 AM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
I hope you know if you have a 2nd Gen 3SGTE (mostly USDM) that an aftermarket BOV will hurt your engine performance. Your Stock one that is designed by toyota is far superior to any aftermarket BOV in terms of the speed at which and the way it releasees pressure.
Also, if you didnt hook up that recirculation tube back to the new BOV and just dumping pressure to the atmosphere you are going to end up running rich and have all sorts of problems. Because its a MAF system and not MAP the ECU cannot compensate for the lost Airflow in the system and it throws it all off.
And your problem above sounds pretty normal, Unless you are running alot of piping or have a huge turbo setup you are not going to get the Loud BOV sound some cars get.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 01-23-2008, 09:40 AM   #3 (permalink)
View Przemik2008's Photo Gallery
hey I had super sound blitz BOV and yeah the guy is right... It makes the car get sorts of problems, I had nice deep swosh sound but when I was accelerating and shift real quick to neutral the pressure went to atmosfere and sometimes the engine were going all the way down and shut down..... Why?
Przemik2008 is offline   Reply With Quote
Old 01-23-2008, 10:51 AM   #4 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Does it have an adjustment knob on it??? Maybe you need to adjust the point that it releases air? As mentioned above... for a stock car.... stock BOV is best. There are plenty of people running BOVs with minimal problems though.
Old 01-23-2008, 11:11 AM   #5 (permalink)
yes it does have adjust knob and i set it for loudest sound which means the huge amount of air is coming out that way, if i set the other way it sound like i close the valve and its poor swash like it want to exhale air but it cant and i dont like that sound, but i wish to have it on it's just incredible how it sounds... Some people thought I am boosting like 30 psi because of that sound wow but I have everything stock including my ct 26 t is there any way i can make it work properly ?
ogh by the way I forgot to say when I installed it the rpms went down at least 1.0 rpms down and had to rase it up manually because otherwise it would shut down sometime the engine was going on very low rpms and should be on 1.0 all the time right?
Old 01-23-2008, 12:10 PM   #6 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
the rfl just always does weird stuff. Depending on how you let off it will make alot of different sounds. My buddy had it on his rx7 and he could get it to make like 4 types of soungs in one blow off. It was aweful
TheEngineer is offline   Reply With Quote
Obx Bov willtotheumm Supra Forum 4 10-21-2006 02:36 AM
engine sounds weird rice Archived Corolla threads 9 10-10-2005 11:36 PM
MkIII BOV...releasing to atmosphere? Wolfie Supra Forum 16 04-03-2005 07:25 PM
HELP my Gen 5 V6 sounds terrible Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 14 02-24-2003 11:36 PM
