boost problems??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2003, 12:26 AM   #1 (permalink)
View 91turbo2's Photo Gallery
Exclamation boost problems???
whats up guys...I thought it was my clutch but its not... i set my blitz boost controller at 14 psi, but in most of my gears at high rpm's, the boost drops...i know it wasnt doing it at 12, so i'm really confused..i dont have an exhaust leak, i dont think i have an intake leak because i would idle weird, so i'm wondering if these are the early signs of a turbo going bad, or am i leaking boost somewhere, because the car is still fast, but it slows down at high rpm because of the boost..thanks guys for the help.
91turbo2 is offline   Reply With Quote
Old 10-14-2003, 12:52 AM   #2 (permalink)
View OEMonkey's Photo Gallery
completely normal if you have a ct26. I dont think it'll hold 14psi past 6000rpm. but I may be wrong.
OEMonkey is offline   Reply With Quote
Old 10-14-2003, 10:17 AM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
What gear are you setting boost in?
..and if you are on the stock turbo, boost does fall off in higher rpms. It is not a high rpm, high flow unit.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
